wiring woes
Bri7man
"Yeah! Take the lemons.."
Jul 17, 2009
580
Torrance, CA
I'm not sure but I'm thinking more that it shows right away warm startup..
If it didn't I would know cause It'd bother me so I guess its normal?
gaboonviper85
3,236
Northeast Philly
I drive about 2 miles at like 30mph before my temp registers on the guage...
mk3_chris
111
sc
Ok well what exactly would happen if say I just didn't use that piece and ran one vacuum instead of the 2 that that thing uses? I'm not going to because I believe my n/a engine has one it pretty good shape i'm just kind of wondering.
gaboonviper85
3,236
Northeast Philly
Look at the hoses that connect too it....then look at where they run....then you come back and tell me what will happen....how's that sound?
mk3_chris
111
sc
haha ok sure will...once i run those lines lol, but like i said i'm pretty sure the one on my n/a engine is in good shape
mk3_chris
111
sc
Well from what I was told by shawn(this mechanic I know) that particular piece is supposed to open when the engine is cold and close when its hot. so it'd permanently stay open, though i don't know why it'd hurt. Is it not just creating vacuum on the tb?
Bri7man
Jul 17, 2009
580
Torrance, CA
The lines run from charcoal canister to bvsv to metal vac line on pvc pipe to one of 2 lines on only the usdm tb to either out the filter thing under the tb or out the other line off the usdm tb, I don't know, or understand it's function either.
I deleted my charcoal canister and am going to install a jdm tb(which only has one vac line up top) for a direct throttle link mod.
My bvsv is also snapped from prev owner so I am not using the bvsv and have the pvc vac line blocked where the bvsv line would come from.
I'm not sure how to fix all this but here's what mine looks like. Engine is still out of car.
Here's what mine looks like quite literally:
Here's what it's supposed to look like:
So If I can get some help figuring out how to run the vac lines with no canister(will install if needed) and jdm tb that would really help out a lot because I've been stumped on this for months.
mk3_chris
111
sc
Well my friend ben just imported his jdm engine and the tb still has those vac lines comin out the top, he just capped them off.
gaboonviper85 - like i said its goin to the tb. JUST to put vacuum on it. Why is it important, why could you just go from the charcoal can to the tb and always have vacuum on it? Sounds like a reasonable thing to me/the other 4 mechanics I've asked.
mkIIIman089
Ohio
^ I wouldn't even bother trying to diagnose the vac system on this car from the internet. You notice the complete lack of a vac tree from that pic with the alternator in the background?
mk3_chris
111
sc
mkIIIman nice .02 man, good suck though it had absofuckinglutely nothing to do with anything with my ?(see pic). But no I guess there isn't any helping me. I don't understand why you can't have constant vacuum on the tb. But as I stated before "I HAVE ANOTHER BVSV ON MY N/A ENGINE ANYWAYS, I WAS JUST WONDERING" guess I'll continue to wonder.
