"Ignition timing" is defined as:
Initial Ignition Timing + Basic Ignition Advance Angle + Corrective Ignition Advance/Retard Angle
Initial Ignition Timing = Setting valve timing & set CPS to 10 deg BTDC
Basic Ignition Timing = A table in memory the ECU selects from based on:
- Intake Air Volume (Ks)
- Engine Speed (Ne)
- Throttle Position (IDL)
- Knock Signal
Corrective Ignition Advance/Retard Angle = Warm-up, Over temp, AFR Feedback, Idle, and Knock.
There's more to it
- Engine Speed (Ne)
- Knock Signal
There's more to it
