will they work?
Turbo Habanero
4,229
Tucson,AZ
In my town right now on Craigslist guy has I set of evo 560cc injectors($150) came off a dsm will they work with a Lexus afm setup ? If i get a apexi safc to tune?
Turbo Habanero
4,229
Tucson,AZ
I think he only has four.
There another guy with evo9 injectors are they all the same?
Also someone with 4 rc550's is it really bad to mix and match? 550's with 560's
I wouldnt mix and match injectors. Who knows what there actually flowing. Yes you can use those injectors. Just make sure the impedance as to weather or not you need the resistor pack.
Turbo Habanero
4,229
Tucson,AZ
Hvyman I have no idea about needing a resistor pack or why I would? Sorry for my ignorance on that aspect. He does only have 4 so ill need to find 2 more. Whether or not I need a resistor pack i do not know. Could you please explain further?
If there high imp you dont need the resistor pack. If there low imp like stock then the resistor pack is on the drivers shock tower.
Idk what the pig tails look like but you might just need to shave off the locating tabs and push the connector on.(not to be confused with the tabs that lock them in)
Turbo Habanero
4,229
Tucson,AZ
I'm assuming pig tail is just the connector with the wires to wire to the harness.
Well it didn't come with any of that just the four injectors said they were from a evo 8 gsr
nd I got a apexi safc with them pages $200 total
ya the pig tail is the connector and some wire. Doesnt plug into harness usually have to solder them in or get a jumper harness.
And ya you will need pig tails. Think there the same as rc.
Turbo Habanero
4,229
Tucson,AZ
hvyman;1734352 said:
Rc sells them. Just good rc injector pigtails. About 6$ each.
hey thanks for all the help your always helping me out i greatly appreciate it.
One more question the apexi S-AFC its the older one but the wiring harness for this do i need a special harness to connect it to the supra or is the harness for it universal?
supraguy@aol
Well-Known Member
Dec 30, 2005
4,241
Atlanta
I just picked up a set of 6 Evo 8 injectors today.
You need Bosch EV-1 type connectors. I just got 6 on Ebay for $35 shipped.
digihonk82
118
Olathe, KS
these injectors are like OBDII....i think... you can find a car with the same fuel injector setup and go to Autozone and request 6 injector pigtails for that car....i think mine were off some mid 90s olds. and they worked! bout the same price as others just no ship and way more convenient!
