Will 1/2 NA-T run w/SAFC on stock 7M-GE injectors?
8,898
I like your project.
Becareful on the injectors. They are not 380cc. Well, you should check the factory manual for the Cressida in your year. Maybe they are different from the Supra. The Supra injectors are rated 276 to 340, max. The only way to know for sure is test them according to the book test.
86supra7mge-t
26
Brew City, WI
tubbie said:
When I was still on GE electronics and 440's it ran pig rich, black smoke everywhhere I went. I had to use an AFC and lean it out 15% to run without smoking. Never hhad a problem with it on 10psi - 12psi.
Under boost? wow, my car is completely different. I was pig rich off boost, and lean on boost.
-Dave
