why switch to 91-92 dipstick
Nomad707
Im From The Bay
Mar 14, 2007
1,039
Santa Rosa, California
if you have the solid metal strip dipstick.. to read it easier you can get a small drill bit and drill holes from E to F, and when oil is at a certain level, it will fill the hole and makes it VERY easy to read.. make sure to clean it after you drill holes too.
what i did was filled my motor in one quart increments to 6 quarts, and i drilled a hole at the top of each quart, this way you can tell oil level down to the quart.
However, make sure your oil filter is primed already so the reading isn't distorted.
MKIIINA
Destroyer of Turbos
Plano, TX
GrimJack;1151818 said:
Negative, Ghostrider. Later model dipsticks are *MUCH* better.
actually you are both right and wrong. the 89+ was redesigned at some point because the original ones were terrible. my brother's pre89 is alot easier to read than my first dipstick but with the redesign its just as good. if i can find my old one i'll take a pic of all 3 lined up.
on my old original one I cut little grooves in to help see the levels.
edit: damn you poodles! you beat me to it!
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
Ok so my question is what car did the flat metal blade come on? I've seen a few people that have this and that's the kind I want. I don't want the cable with the little lead tip, I want a flat blade all the way down.
MKIIINA
Destroyer of Turbos
Plano, TX
just order one for an 89+ supra and you will get the new style one. the "older" style isnt available any more
They ALL have a wire, dunno about the N/A dipstick though as it might be a straighter shot at the hole and not need the flexability.
I polished off the yellow tint on my original one, but it comes back for some reason. Guessing some reaction with the oil or the metal oxidizes like that.
Pre-89 is definately the easier to read, but it's ugly and that yellow part gets nasty...
SupaMan
Want The Boooooossttttttt
Oct 12, 2006
1,101
Cape Coral,Florida
GE's are a faily straight shot down and mine doesnt look like any of the 3 you posted. I have a flat peice of metal all the way down, but whos to say mine is factory. It could be from anything for all i know.
Ive got a 15301-42012 sitting here brand new in the package if anybody wants one.
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
supaman, got the GE dipstick and mine's the same way, a flat piece of metal with maybe a 20 degree bend in it.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
I have the pre 89 GE dipstick, i dont know if it would be compatible with the turbo engine though because it is much shorter in length than those pictured in the previous posts
SupaMan
Oct 12, 2006
1,101
Cape Coral,Florida
Yea it is alot shorter 5-7 inches if i remember correctly.
Heres a pic of my GE dipstick next to the newer style turbo dip stick.
got_boosted
I need a turbo! >:(
Mar 3, 2006
608
Sacramento, CA
This is funny. I never even realized there was a difference, and I've had Supras from every year range. The only one that was different was my 88 N/A which was probably the easiest to read. I always hated the little chunk at the end of the wire. I like my 2JZ. It's just a typical dipstick.
Collin
