D
Yep. Being low on coolant causes a cavity near 5 and 6 according to Toyota. Not necessarily a local shitty dealer who doesn't know, but Toyota themselves. This was covered on another site a few years back.Isn't there anyone out there that has any data on the water flow in the water jackets? Is it possible the water pump impeller is cavitating leaving the water still as a lake in the water jackets especially at the rear of the engine where Major flow is needed the most? Or has this gone uninvestigated for years as to a solution to SOME bhg's? I believe it is and one reason is the gurgling sound in the heater. If the impeller had an anti-cavitation plate on it, it would be pumping water like a mofo and instantly flush any air out of the tubing system and all this talk about parking your car pointing to the stars to bleed the air from the coolant wouldnt exist.
Most of the time, at least what I read on the internet, the BHG is a symptom of another problem. Overheating is damn good way to lose the headgasket on an iron block/aluminum head engine. The head warps, and it damages the gasket as a side effect. This is why Toyota redid block designs on many models, including 4Runners, Celicas, and Supras.I'm not sure what effect heat would have on the gasket - I suspect that overheating would cause your head to warp before it blew the gasket.
I dont see what is different in this pic ?suprageezer said:Here's an example of what I believe a Supra Water Pump Needs. I made this exact pump myself a few years ago for my 440 using a MP Alu pump, all I did was weld a plate on it just like the Milodon in the pic. It's easy to make yourself as you can see from the pic I added. I dont have a cooling problem currently but if someone does I am sure this could help solve it. I will be uising a pump off my old BHG'd motor to make a mock up soon to show as an example.
