I've done some searching on here and SF and I just want to hear from the guys that put the stock 2jz cams into the 1jz. So far I know that some of the cam has to be machined to fit into the 1jz. I'm trying to find out some dyno numbers (butt dyno's would be useful as well) to see if it's worth doing.
I read that putting in the cams would bring the powerband all the way to redline. We all know the stock 1jz runs out of power at around 6100 or so. I just want to find out some solid answers and gains from using the 2jz cams.
I also want to find out where you guys got them machined. I just want someone that knows what needs to be done to the cams so they will fit and not screw anything up.
Thanks for looking.
Thanks for looking.
