Who is a RIM HOR!!
FredMk3
mk3 for life!
Sept-Iles/Quebec
Your car really looks awesome with those rims! The car is very clean too! :)
Just got mine today...Wow! They're so light...16 lbs for 17". Can't beat that! Can't wait to put them on the car! :icon_bigg
BTW BorHor did you saw my pm?
91T breezen'
ROMNEY/RYAN 2012
Apr 4, 2005
1,149
NOYFB!
kwnate;985940 said:
Rims look great, but the tires look like donkey balls.
Agreed! But "wet, donkey balls"!!!:icon_razz Those rims don't look any different if were to have gotten them in the correct offset that would have allowed you to run a 'real' tire size! say, a 275/35-18, rear, and a 245/40-18 front. Something you should consider, is the safety factor because of the Supra's considerable bulk. You will build excessive heat in a tire that cannot properly hold it, because of the lack of volume inside...i;e too small of tire for the weight! Good luck this summer! Rims are definately sick though!:boink:!
BorHor;987302 said:
If I actually wanted to get some that would fit more meat I would have got a higher offset set. But I want those aggressive stace that not many Supra people go for. I might go and just buy a higher offset pair for other uses later when I actually put down more power.
Ahh I see sorry didn't realise you did that on purpose..
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
Yeah I did haha. I wanted to have a stance like. Not really sure why but I do at this moment. When I do put some power down I will get a set that you guys will approve of haha, not that I really care.
prsrcokr
Motörhead
Apr 3, 2005
349
Richmond
Boris, once you figure out the fender clearance and can put some miles on them you'll like them. I run a narrow tire/wheel combo (not the 45 deg. angle like yours) in 235/255 on 9&10 and they're very nice to control in a slide compared to a more square fitment.
My +35 and 17" version doesn't look as good now that I've seen the 18's on your setup though.
Brian
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
I put on 245/40 tires today for the rear. Slight rub I have to take care of though. That is basically the max I can put back there with out adding more camber. And as for camber this is the most positive I can actually get too.
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
