Wheel Fitment & Question Thread
Doat
2,599
Houston, TX
Enkei RPF1 17x8 +35 and 17x9.5 +38 tires are 245/45/17 and 275/40/17
A70BoosTFienD
A.K.A. Knight Rider
Oct 28, 2008
224
Orlando, Florida, United States
magnumrx86;2007654 said:
18x10 +12 offset front with 265/35 tires, 18x12 +17 offset rear with 315/30. obviously not a good fit if you don't intend to modify fenders, however i'm doing guard work and running bolt on flares.
[THUMB]http://imageshack.com/a/img838/5436/3zu2.jpg[/THUMB]
[THUMB]http://imageshack.com/a/img838/1083/akuh.jpg[/THUMB]
[THUMB]http://imageshack.com/a/img839/6960/h42w.jpg[/THUMB]
Really aggressive offset but damn it looks good lol. can you push the car the way its set up?
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
going to be buying some new Varrstoen ES7's 18x9.5 this fall sometime
running 245/45/17 front, 275/40/17 rear currently
want to run the same size tires, just in 18's
i want to run just a little (not much) camber in the front, and same thing in the back. -1* i think is what i want.
i think +35's will fit great but they also offer +22 in the same wheel
i want an almost flush look, but will clear the fenders at full bump
any ideas what offset will look better for what i want
gsxr141
1,158
10
rochester
^, go with 18x9.5 +22 rears with a 265-35-18. you might have to roll the fenders, but that's it. i have 18x9.5 + 15's right now with 255-35's and they fit great.
also, i'm lowered on h&r race springs...... they are pretty low for springs.
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
I don't think I want to go down a tire size in the back, I have traction problems as is and am shooting for more horsepower. Would +22 be flush or poke out a little bit. 35 might be a better option for me
Sent from my LG-LS980 using Tapatalk
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
Go +35 all around. You should be able to clear 275 all around. A friend of mine cleared 18x9.5 +34 all around with 265 all around no rubbing so 275 should clear. I'll see if I can find a picture.
You could possibly clear 275 with +22. Depends how low. I clear 275 with +25.
Also better quality tires make a world of difference than just size.
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
i was thinking of going with nitto NT05 tires as well (since im going from 17 to 18)
much better rubber than i have now, i bet i could also go down in size since its a better tire.
good point
ill have to do a little more research and see what offset will work better for me, and the new tires i choose to go with
A-to-the-J
Panda™ and Pre-89 Gracer™
Feb 19, 2006
1,080
Anaheim/West Covina, CA
Front
18x9.5 +12
255/35
Rear
18x10.5 +22
265/35
Tein Coilovers
Rolled fenders
No rubbing so far. Haven't taken any hard corners or on ramps yet. But I'm confident they won't rub. Going to get an alignment and corner balance soon.
I should have gotten 275 or even 285 in the rear, but these were tires I had laying around. Figured I would see what I can run and get better tires after. However, these are temporary wheels and got them just to get a better feeling of what sizes I can run. Permanent wheels are still being worked out. I want to push the stock body to the limit without major fender work or over flares/fenders.
Sent from my SAMSUNG-SM-G900A using Tapatalk 4
1990MA70
110
Cochrane, AB
A-to-the-J;2009310 said:
Front
18x9.5 +12
255/35
Rear
18x10.5 +22
265/35
Tein Coilovers
Rolled fenders
That is actually perfect...
I know what ill be using for inspiration now
A-to-the-J
Feb 19, 2006
1,080
Thanks! Definitely didn't expect that response. But I've been doing research in this thread and test fitting what can work. I'm always happy to help out a fellow car enthusiast! I'll have another part when I save for what I really want ;)
Mk3_Eddie89
8
Los Angeles
Dont know if this has been asked already im new here on the forums, but what's your guys opinion on the my set up i bought my car with i have 18' wheels 215, r35 up front and 225 r40 in the back. Should i stick to that or what would be a good wheel setup for a daily driver.72131_699949246713228_7758629180286928657_n (1).jpg I believe the wheels are 18x7.5
1990MA70
110
Cochrane, AB
Mk3_Eddie89;2009771 said:
Dont know if this has been asked already im new here on the forums, but what's your guys opinion on the my set up i bought my car with i have 18' wheels 215, r35 up front and 225 r40 in the back. Should i stick to that or what would be a good wheel setup for a daily driver.View attachment 73259 I believe the wheels are 18x7.5
Looks pretty good but personally id like a bit more tire. Might be easier on bumps and would probably perform better too. Just not quite tall enough for me but that's just imho. But its more about what will fit in those well's without rubbing and how big of a tire will fit on a 7.5"
