Wheel Fitment & Question Thread
SiberianDVM
97
Augusta, GA
I'm building a MkIIIfor ChumpCar racing. Currently have 1 set of wheels in 16"x7" with 40mm ET, plan on running 225/50-16 tires all around.
I need at least one more set of decent, strong, straight, cheap wheels in 16" with approximately the same width and ET. On ebay I see these two sets, but they don't have the ET listed. Does anybody know if they will fit the MkIII without any problems?
Thanks.
http://www.ebay.com/itm/281207213248?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
http://www.ebay.com/itm/281198470988?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
K_SHAN
don't taze me bro!
Jul 3, 2009
357
eagle, IDAHO!
19x9.5 +22 (245/30/19) **rolled**
19x10.5 +22 (305/25/19) **Roll&Slight pull
K_SHAN
don't taze me bro!
Jul 3, 2009
357
eagle, IDAHO!
I could easily put another inch of rim/tire width under without even modifying the suspension (stance gr+ coil overs)
11.5 with 315s would be cake.. Now If I added the coilover spacer that SJ aka 2jzmk3 has.. I could fit 325's (obviously I would be adding width inward)
Ya I have mine in as well. That's a pretty small height size tire. I don't think I would like to go smaller than 35. Tho 19's do look good.
gsxr141
1,158
10
rochester
how much room is on the inside of the rear wheels? i love the wheel and tire size, but don't want them sticking out that far.
K_SHAN
don't taze me bro!
Jul 3, 2009
357
eagle, IDAHO!
I have another inch of clearance to the nearest suspension component.
I going with a taller height in the back. (35 series) but just because i want a little taller overall height. (gear ratios ;) )
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
mk3supralove;1986586 said:
I have 18x9 +25 up front with fender roll, the rear 18x10 +21 with roll and pull both no rubbing
Sent from my LG-P500h using Tapatalk 2
Do you have to roll/pull your fenders? Do you know how much they rubbed before? How low are you? What size tired are you running?
Curious because I have a set of 18x8.5+20fronts and 18x9.5+20rears sitting here in going to get tires for soon
gsxr141
1,158
10
rochester
i have 18x9.5 +20 rears, with 255-35-18s. the tire's not even close to the fender. i did just a roll on mine. i think i can fit a 275-35 on there with no issues.
i have the same front wheel size as you. i'm running a 225-45-18 for now. just a roll up front too.
mk3supralove
28
Kelowna
I have 235/40/18 front, 255/35/18 rear, however I ordered 275's literally last night to replace the 255's.
I run 255/35 on +25 up front. They will fit on +20 fine. But if your slammed might pull on fender at full lock sometimes.
When I ran 265 up front it pulled on the fender.
