There are hub centric spacers. I know project kic makes rings for their's. My dad's M3 has a hub centric one too and it is a sandwich type.
Sawbladz said:Can you expand on your rubbing issues? When you say it rubs in turns, is it rubbing on the outside fender lip or on the inner fender? What suspension are you running? Since you mention TEMS I am going to assume some springs (H&R?) and Illumina 2's? It looks like your wheels are almost up into the wheel wells, it this true?
heyitsdatguy said:It's rubbing on the inner fender. I can see where the inner fender is getting alittle damaged from the tires hitting the fender. I don't know what kind of suspension I have because it was already lowered when I bought the car. I leave the tems button on "sport" to stiffen it up when I turn to avoid the front tires from hitting the fender. Yes, the wheels are in the wheel wells about 1/4 inch. I will be changing my suspension sometime next year so it'll be a little higher.
Dawly
twincam187 said:heres some 18x12 -20 lol
severe body modification required
