Dunno what to tell you man, you could replace the entire brake system for less than half what you're going to be paying...
Poodles;1345256 said:Dunno what to tell you man, you could replace the entire brake system for less than half what you're going to be paying...
Alec;1345259 said:like I said, not an option. What I'm contemplating now is whether to order the parts from the shop or order the parts myself and have them install it. If I order the parts myself I'd be getting more/better parts but it would cost me more. I'm curious to know whether or not it's worth the extra $$$.
rayall01;1345261 said:These are your BRAKES man! Of course it worth it. The better your brakes are, the less likely you are to kill yourself, or someone else.
Poodles;1345265 said:If you order the parts yourself the shop will NOT warranty them. They never do as they make half their cash on ripping you off for the price of the parts.
<=== Delivery driver for a major parts distributor for shops
If you saw what they paid you'd be pissed...
iwannadie;1345285 said:Well your decision has pretty much been made for you. The whole reason to get the work done at the shop is to have a warranty. A warranty you won't have using the 935 kit installed at that shop. You can't do the work yourself or shop around for another shop.
So, that leaves you with going with the parts and labor the shop quoted.
Are all Akebono's ceramic?Poodles;1345287 said:those pads are pretty good, they're ceramics...
It's up to you really, but it looks like you really don't have a choice...
Poodles;1345291 said:They're low noise and low dust and about the same stopping power as a stock pad.
Poodles;1345294 said:Be about the same IMHO, the Porterfields on the other hand are a high performance pad...
Poodles;1345297 said:A good brake fluid flush and a good pad break in and they'll be fine...
Poodles;1345303 said:They should if they're charging that much (but I'd ask)
Poodles;1345349 said:they usually use DOT3
I also noticed in the pics that your calipers are painted red, the replacement caliper isn't going to be red, and how did they get red to begin with?
