Rennat;1141828 said:
wow... your one of the smart ones. your bottom end should be pretty good then. just drain the oil, fill with some generic supertech 5-30, run that for 5 or 10 miles, then change it out for the good stuff. that way if anything shows up in the oil after you do the BHG you wont be wasting 40-50 on high quality synthetic oil.
stock head gasket is 1.37... and your head is at 115mm... so that would make you have a 2.37 HG... but a 2.0MM would do just fine, and if your have the extra money get the HKS STOPPER... other wise just get a titan headgasket if you dont have super high intentions for this car...
Thank you so much Rennat...
That was the answer I was dying for...
All I wanted to know is the exact measurements and what size gasket is recommended..
Well, this isn't my 1st Supra, its actually my 4th, I own 2 as we speak, 1 is 89 NA, and this one 90 Turbo. This is my 1st turbo of all of them.
Thank you guys for all your help (and patience)
I'm going to order 2mm STOPPER!
Wish me luck.
Regards,
PAUL
