Whats the best BOV i can run?
Turbo Habanero
4,229
Tucson,AZ
gaboonviper85;1398650 said:
Why....it's seriously a waste of time...
Not to mention it's clearly obvious at that point that you just want the noise over the function....that = RICE!
O i thought there was some bonus to it....
gaboonviper85
3,236
Northeast Philly
Not really....somewhat helps with stalling upon decel from a high boost pull...but if you learn not to push in the clutch right when you let go of the gaspedal while slowing down then stalling won't be an issue...(this is all from a full boost pull).
Putting a bov on a stock ecu supra is ricey no matter what unless you seriously need a bigger bov for a bigger turbo...even then the hks ssqv can be recirculated as well as the synop.
Turbo Habanero
4,229
Tucson,AZ
yea.
Right now i am going through the process of turning everything to hard pipes (intake/TB pipes) thought might as well put a newer bov on it i plan on building it up piece by piece sense i can Poop the money out..
ALSO going to get a new Intercooler get rid of the stock one just don't know what to go with yet.
Turbo Habanero;1397924 said:
Another question? I only get partial boost in 1st and 2nd And full 3rd-5th.
Heard it was made to do this?
Turbo's are proportional to load, less load in lower gears so you run out of rpm usually before you make full boost, stick a car trailer on the back and you'll see full boost in low gears as you load it up.
This is why taller gears in the diff are often faster in a turbo car than high numerical lower ratio gears.
With a Fat Mk3 and it's little engine it's a balancing act to find the sweet spot.
91T breezen'
ROMNEY/RYAN 2012
Apr 4, 2005
1,149
NOYFB!
Justin;1398618 said:
stock, or Bosch. seriously.
Listen to this guy! If you are still on the maf, at least run something that is re-circulated, or your car will never run perfect.:nono: Bosch bypass is really a quality replacement, and sounds pretty cool from inside the car!:naughty:
Turbo Habanero
4,229
Tucson,AZ
Whats the best way to get rid of that for the Mass air Flow
Fuzz420
Are U Here 2 take My Baby
Turbo Habanero;1398941 said:
So i think im going to order the Blitz DD any last advice?
Dont buy it unless it can be recirculated
maft pro+speed denisty=no afm
or hks vpc or standalone
If you go this route then you can get one of the BOV;s that vent to the atmosphere
Justin
Speakers?
Spokane, Wa
Don't.
There's NO reason to unless you're going for way high power.
I had the Maft Pro, and VPC while I had my Supra and neither of them ran as well as the AFM with an AFC to make minor fuel adjustments.
Turbo Habanero
4,229
Tucson,AZ
ok.
I don't really care if i have the noise. I just want to know the best route to take my car. I Guess i got to learn how every thing works/Means some how :)
Justin
Speakers?
Spokane, Wa
Turbo Habanero;1399456 said:
ok.
Then do the Bosch.
What are your final goals?
Turbo Habanero
4,229
Tucson,AZ
Justin;1399449 said:
Don't.
My long term plan is 12s so im just tyring to figure out the best way to go and try to avoid fucking up my supra. I just got done rebuilding the motor back to stock specs had everything done. Less then 200miles on it so far ;)
Fuzz420
ok.
The noise isnt an issue for me, i run speed density plus i run a tial and i vent to the atmosphere with a smile on my face.
If you reallly really really just have to have it get your bov of your liking and if/when it stalls on you then you know why as per the aforementioned post.
As for bov choice from me, go tial.Goodluck with your decision
Turbo Habanero
4,229
Tucson,AZ
Thanks another note my friend told me i just have to do something with the Aif flow meter.
lewis15498
Don't blame ebay cheapass
Sep 28, 2008
1,397
Raynham, Massachusetts, United States
Turbo Habanero;1399502 said:
What exactly would i need to run this ? anything special thats not stock on the car?
http://www.maftpro.com/tgen2info.shtml and is this a good decision if not can you refer me to a better route to take and please be inclined to explain how it works.
Everything you need: http://www.suprasport.com/Complete-MAFT-PRO-install-Solution_p_687.html
MAFT Pro is a piggyback fuel controller. You need to do alot of research before you use it, or pay someone else to tune it. You can easily destroy your engine by making a mistake. A guy on here recently did this, he thought he was running lean when he was running rich, and added more fuel worsening the problem. Had he made that mistake in the other direction, he would have likely tanked his motor. I'm all for DIY but you gotta do your homework and know what your doing first.
BOV's protect your turbo from compressor surge. You dont need one if you dont have compressor surge.
Could be wrong but it sounds like you want to do this all just so you can vent into the atmosphere. If thats the case, theres much better ways to spend $1000.
Adawg
30
Tacoma
hey i got a question.
what would be the "most preferred" BOV for single T60-1 (from driftmotion) on a 2jzgte? NO HKS SSQV please.
Turbo Habanero
4,229
Tucson,AZ
Like i said i Don't care for the PSSSH noise just want to know what all i need and what steps ill need to take to make good numbers Beside Exhaust and Intake.
I do need to do research and have been Just also asking you guys for any advice/Info you willing to share. Its not like i plan on doing this over night.
Although that would be nice lol
lewis15498
Sep 28, 2008
1,397
I would say Synapse Synchronic. Other answers would be HKS and TIAL.
Well then as I said the complete kit from suprasport has everything you need including the wideband. As far as I know thats the best price out there.
You want to get some good numbers on a budget, Hardpipes, and a good MBC (get the MAFT Pro working before you increase boost). A new intercooler would be a good idea as well. I just got cx racing factory replacement IC piping kit for 230 shipped. I belive they have a similar kit that includes a replacement intercooler as well. Theyre readily available on ebay, dont buy it now, make an offer, you will get a better price.
Downpipe with elbow, a good catback and highflow cat or test pipe will help decrease your spool time. If your factory cat looked anything like mine, you just have hard claylike chunks getting stuck in your exhaust. FYI Hollowed out cats dont help, they hurt.
