Whats odd about this guage cluster....
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
Lets test yall's skills in peekin stuff yo.
Take a look at my new guage cluster....
Lets see who has a eye for this stuff.
I know its gonna end up bugging the hell outta me so if anyone has what I need. I wanna work out a deal :naughty:
b005t3d
505
bellevue,nashville, tn
depends on what kind of car its going into. is it going into an auto? is it going into a turbo? or the coolant gauge is f'ed. i didnt think they were supposed t sit with a reading when not energized
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
N/A's didn't come with TEM's so it has to be a turbo cluster with a voltage gauge. Guessing whoever had it put in a after market boost gauge and put in a voltage gauge in place of the stock boost gauge...not a bad idea really. Sucks for you if you wanted a stock boost gauge.
Brewster
So it goes.
Apr 15, 2005
1,156
Morgantown, WV
TEMS was an option on NAs.
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
Yup, the sport package, but I believe Na's had 140mph clusters, where as the turbo's where 160, so there was some gauge swapping done, whether it was the speedo, or voltage gauge... I do not know..
LOL @ Brewster's sig.
Edit: It appears to be the Voltage gauge was swapped in, the needle is a different color... and it looks alittle tampered with.
lifesnotfair
356
Dominican Republic
The N/A voltage gauge is also 86.5-88, different needle.
N/A's with sports package DID come with TEMS. But it appears to be a turbo cluster because of the redline and the 160mph.
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
No, 89+ NA's had 160's, I would know, mine has one...the only thing I can see in that is the redline is lower than my 89
Big Wang Bandit
Feb 21, 2006
7,551
Bingo! 89+(90) cluster with an 87 volt meter lol.
I just put it in the car and guess what... It diddnt work.. Gah. Im hoping when I took it apart to remove the boost guage i just diddnt tighten somthnig all the way. Im gonna clean the contacts too lol.
I was pretty dissapointed when everything was in and it diddnt work :/
Oh well.
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
Yea I was wondering if it was raised for the 90+'s.
The redline is also lower than my 89, 90-92 they lowered it to 6250 I believe.
I also don't have that center light under the Speedo between the Seatbelt and Brake wanring lights... so definetly a 90-92 with NA pre89 volt gauge... is my guess.
Edit: Damn Hells already unveiled the answer.
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
yeah i think you just found it, thats a pre-89 needle with a 91is dash cluster..
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
so you bought a turbo cluster and swapped in a voltmeter from your pre89 cluster? and the voltmeter worked in the old cluster? Poopy! double check your wires, and make sure you compare the way that voltmeter was connected to the original cluster and how you have it now.
Im wondering though. Would a NA 87 voltmeter even work in a 89+ turbo cluster. Ive seen the backs of both but not at the same time, so I got nothing but memory to go on...and at my age thats not really enough...................
What was I saying again?
Big Wang Bandit
Feb 21, 2006
7,551
Ill have to check. But nothing was working.. My temp needle reset itself so I know that one worked. But none of the other guages were moving... Im gonna take a look.
Is m first problem that its a 90 cluster going into an 87? lol
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
actually... my 89 has those needles... the one's with the orange stripe must have just been 86-88.
And is that light in the middle I was talking about a TEMS thing, or a 90+ thing... or what?
Jeff Lange
Administrator
4,926
17
Sunnyvale, CA
jefflange.ca
It's a 1990 USA 5-speed TEMS gauge cluster with an 86.5-88 N/A Voltmeter.
You can tell it's an 89+ cluster because of the needles and less lines on the gauges, as well as the cruise light added on the tach, as well as the change to the indicators (made them all black). You can tell it's a 1990 because it has the airbag light and lower redline, it's not a 91-92 cluster because they had more lines added on the speedometer. It's a USA cluster because it's in imperial and the fuel gauge has "UNLEADED FUEL ONLY" written on it. It's a 5-speed cluster because it doesn't have the A/T lights on the tach. You can't tell if it's Turbo or N/A from the pic.
Anything else? ;).
(PS: Turbo and N/A clusters had the same speedometers, they are 150mph for pre-89 and 160mph for 89+).
Anyone wanna tell me what's unique about my cluster?
