What part is this
Zrain25
639
Pelham,New Hampshire
Passenger side on the the firewall near the abs. Had nothing hooked up to it only the electrical connector. I think it is part of the charcoal can but idk . Do I need this like I said nothing was hooked up to it only the electrical. Will it cause a check engine
Grandavi
2,664
Calgary, Alberta, Canada
Heater VSV allows the water to flow through the heater core when it warms up. Its generally vacuum controlled but it has an electronic solenoid on it that is supposed to shut it when your climate control is set to 18 C (coolest.. not sure of the number in F) so that you can run the AC colder. Most of the Supras I have seen (mine included) had the solenoid bypassed because it failed (simple vac line reroute) and you wont notice it.
Yours has the white plug showing so the solenoid is on that valve currently.
If yours had no hoses going into it, chances are your heater core leaks and was bypassed. (not a fun job replacing the heater core because its the last peice of the puzzle when dissassembling the entire dash).
