I agree with a 10w30. I'v been doing tons of research and even read, not too long ago, a long write up from a chemist that retired from Shell. His life he spent it developing engine oil for Gas and diesel engine. He explained and debunked theories uses today of the use of oils.
After spending close to an hour of reading his write ups, I understand that the most crucial point in the life of an engine is "cold start ups". At operating temp, most engine wont have much difference in the viscosity or weight of it since it pretty much thins out.
At start up, the lighter the oil the faster it can charge and lube your engine. He also went to explain the difference between synthetic and Non synthetic oils. Regular oil, although it goes to the bottom when the engine cools off, leaves a very thin layer on the walls of the engine, synthetic leave an even thicker wall, reducing the wear at start up even more.
In conclusion, I am going with 10w30 from 20w50.. NUFF said!
