IJ.;1349148 said:A LOT of these guys could fuck up a Briggs and Stratton rebuild Joey
are you saying i will?! cause i wont
Doward;1349178 said:BTW, MAKE CERTAIN you prime the oil BEFORE you ever spin the motor over. You want to see oil at the cams, then (with the EFI fuse pulled) spin the motor over until you see oil pressure - check for leaks, THEN fire it up.
7M-KDL;1349419 said:just dont put rods in it...guaranteed not to have rod knock.
oh and btw, there is a "slight" chance it wont run but at least it will be super quiet. good for a coffee table
rayall01;1349489 said:That's just wrong!
7M-KDL;1349503 said:oh i dunno, i kind of want an engine for a coffee table
and let's be honest, that is the only way to be 100%
rayall01;1349504 said:Yeah, but not a 7M! Some worthless V8 or something!:aigo:
7M-KDL;1349510 said:well thats true. im just worried a v8 wont even work right as a coffee table
for any who don't know, im not dissing the 7M at all, i still run one
IJ.;1349513 said:Better chance here finding a worthless 7M than a worthless V8
rayall01;1349560 said:Yeah, here. But there's tons of useless V8's in countless junkyards across America!
7M-KDL;1349592 said:if we are strictly going on mass numbers i think it is safe to assume that there are less junk 7M's than there are junk v8's (if that makes sense) basically there way more junk v8's in the world simply because they are produced in greater numbers than the 7M
rayall01;1349597 said:Not only that, but the percentage of enthusiasts per 1000 of each type of engine, is much higher for the 7M, than for all the different models of V8's combined, therefore people are less likely to junk a 7M.:boobies:
tbcmorris;1349750 said:you guys all need >>>>>>:1zhelp:
