what is the best setting for timing:
mk3bandit
Jonathan D.
Feb 10, 2010
56
Denver, North Carolina, United States
i am rebuilding my 7mgte top end, replacing the"HKS 1.2 MHG, arp bolts, water pump, dual 12 electric fans, valve seals, and all the vacuum lines". im going to be setting the timing in the next few days. i want to know what the best set timing for a mostly stock 7m.
any help will be great.
Thanks
mk3bandit
Jonathan D.
Feb 10, 2010
56
ok just one more question. im not sure where top dead center is on the Camshaft position sensor. i just dont want to put it in wrong or mess anything up. im going to be setting the timing and putting the sensor in tomorrow, if my turbo comes in on time. i have the crank and cams all at top dead center, just ready to get it back on the road after the blown head gasket.
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
Those blue hoses where did you get those? If you got them at a auto store be careful. I bought one and placed it on the brake booster hose like you have, motor got hot and vac line pinched I had almost no brakes.
j3r3my
240
mass
those hoses suck..no offense just that ive been through it.when they heat up they sometimes suck into themselves and some may melt..just a heads up and as for timing,time it to specs..and also as for the timing marks 0 deg on the crank pulley then the cam gears have lines in them that you match with the lines on the rear timing cover on the head and lastly set the cps accordingly..gl with your project!
92TealSupra
Sep 2, 2008
1,584
Great Lakes State
mk3bandit;1636008 said:
ill have to keep that in mind. im going to keep the old ones. they were in good shape, just wanted it to look good after polishing everything up after replacing the head gasket, valve seals, turbo, and a few other things.
Good, to hear you're keeping those. You might pinch a line that would be for the FPR; which would be no good. There are other important lines as well.
enjoi.this
Formerly ChrisC
Aug 18, 2008
674
Kelowna, BC
Now that you have all the timing marks on the cams and crank lined up. Hold the CPS in your hand and turn it to line up the timing marks on it. You will have to eye ball it when going into the head so its in the middle of the adjustment range.
The CPS will turn as its going in because of the spiral cut gear. But make sure the housing still stays lined up. Its kinda funky to get it right but once you figure it out your good to go.
mk3bandit
Jonathan D.
Feb 10, 2010
56
ok i found the answer to my second question.http://www.supras.com/06/techcenter/images/881.jpg
---------- Post added at 12:54 AM ---------- Previous post was at 12:50 AM ----------
thanks man. i just dont want to mess up the old 7mgte. thanks fro the tip, its going to com in good use.
enjoi.this
Formerly ChrisC
Aug 18, 2008
674
Kelowna, BC
no prob, you dont really have to worry about messing up the motor as long as you put a timing light on it. It will either run like shit or make no power if its not right.
mk3bandit
Jonathan D.
Feb 10, 2010
56
im not sure if this is how the CPS should be at TDC. im just trying to do it right the first time.:aigo: its driving me crazy now, this is the best i can get it to line up. i lined it up to TSRM. just not 100% with this CPS this is the first time with a car with out a distributor. any help would be great. Thanks
