balong said:
So heres the story. I fill up gas on the way to the club. find a nice parking spot.
parked, then i rev my engine a little bit. i here a 'wooshing' sound ive never heard before. im like.. what? thats not right. do it again. still there. hmmm...
then my friends like..holy eff yur leaking oil.. the oil was dripping on the right rear from the under body. it was driping fast. and my oil level totally dropped.
anybody have any ideas why it would happen out of the blue?
mind you it was a smooth ride all the way.
how did you see that the oil level "totally dropped"...did you read the oil pressure gauge? that reads, as it says, the PRESSURE...not the level. you can be low a quart and still have pressure...you can have 8 quarts and still have pressure. but if you checked the oil... thats a different story.
if you used the check oil dipstick, how soon after shutting off the engine did you check it, and when was the last time you checked it? how was it then? if you check the oil too soon after shutdown you will have a low reading because the oil hasnt settled back to the pan yet.
rallysoob said:
Woa Woa... That water fall sound is exactly what again? And how do i fix it? upon initial startup., My car has the little waterfall sound behind the dash for about a minute or 2
water fall sound is air in your coolant flowing through your heater core. you can fix it by "burping" the cooling system. its been addressed sufficiently (actually its an ungodly amount of times) so a search will do you good for the possible causes and the fixes for your issue.
