What do you guys think of these wheels?
got_boosted
I need a turbo! >:(
Mar 3, 2006
608
Sacramento, CA
Option 1:
Front 17x9 with a +24mm offset
Rear 17x10 with a +20mm offset
Option 2:
Rear 17x10.5 with a +20mm offset
With the right wheels spacers (10mm?) they will fit nicely. My only concern is that 10.5 on the 2nd set may be too wide. The 2nd set is more affordable, and I'd like to stretch the tire a little for a nice breakaway feel. (These will be my track wheels.)
Oppinions?
Thanks,
Collin
got_boosted
I need a turbo! >:(
Mar 3, 2006
608
Sacramento, CA
BorHor said:
Uhhh on your car.. they will stick out like a mofo.
17x10 is only .5 wider than MKIV wheels which are nowhere close to sticking out like a mofo. lol
These are from "that auction site". Search "17x9 Saleen". Option 1 is $534.00 plus $82.00 for shipping.
Yeah, #1 does look pretty sick. :D
Collin
got_boosted
I need a turbo! >:(
Mar 3, 2006
608
Sacramento, CA
BorHor said:
Offsets -_- only .5 wider yes. but the offset is like 30mm less too.
As I understand it, greater offset means more sticking out so since the offset is less on these, that can be corrected with spacers. Was I mistaken? These are Saleen replica wheels, and I have seen mustang wheels on MKIII's before. They fit very well.
Collin
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
Lower offsets = out more. It can be done. I mean my offsets are even lower. But you are also on stock suspension and probably running close to 0 camber. They will stick out noticeably. Let me get you specs compared to your current sawblades.
TurboFreak
NOBAMA
Jan 22, 2006
1,374
East Coast
Lower the offset, the greater they stick out of the wheel well. The higher the offset the more they are tucked in the wheel well.
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
First set. the 9" will come out 38mm, 10" will come out 55mm
Second set. 9" will be the same as the first . 10.5" 61mm
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
they are in the wheel thread in my sig. Umm the current ones should be on the last page if not last few. There are also good size/ offset combos you can look at in there.
bowsercake
828
Irvine, Ca
Those are mustang wheels, which are very cheap. The 9" mustang wheels will probably fit in the back but the 10-10.5" ones will definitely stick out.
rodel
SoCal
May 19, 2005
2,266
SoCal
About the rears, with regard to the offset that you'll need and inner clearance
you'll have to roll the fender and go with a really high offset for the widths that you want.
10", the offset should be around +50, then you'll have 51mm less clearance at the back of the wheel.
10.5": offset should be around +56, then you'll have 63mm less clearance at the back of the wheel.
How much clearance is there from the back of a stock wheel to the lower control arm?
As far as which wheel I'd go with: Option 1.
got_boosted
I need a turbo! >:(
Mar 3, 2006
608
Sacramento, CA
I was really just playing around with affordable options, so I'm not heartbroken over this. I'm also not neccessarily looking for the widest wheel possible. My plans are to set up the car for road course racing. I want enough tire that I can use every bit of 500-600hp coming into the straight portions, but I need to be conservative enough with the rears that I can put a similarly wide tire in the front, otherwise it's going to push around every turn.
I've been cosidering MKIV N/A wheels because 16x8 and 16x9 with sticky tires would work very well.
Hey, at least I learned something in this thread, even if I was just being retarded and getting the offets confused.
Thanks guys!
Collin
