I had a similar problem before I felt my clutch was weird every now and then, so I replaced the master and salve with OEM from Rockauto both Aisin like yours and haven't had problems since.BrandonW;2052672 said:Ordered new asin master and slave cylinder because I was driving and boom no clutch it just goes to the floor rockauto had them both $56 total surprisingly cheap and plus the little bit extra off with the 5% discount code lol
The pedal feel has been a little weird for the last 2 months a little more stiff and like "crunchy" as if there was dirt in it or something when just pushing the pedal down
Hope that's all it was parts were cheap enough
Is that a 7M-GTE or 7M-GE and where did you get that oil filter adapter?George_Bonilla;2052594 said:Damn i need to do some more cleaning but you get the idea, i replaced the stock oil cooler.
7mgte, the adapter came with oil cooler kit.zonian91;2052676 said:Is that a 7M-GTE or 7M-GE and where did you get that oil filter adapter?
Sent from my SM-N900P using Tapatalk
I got a cheap godspeed universal oil cooler kit. Just try searching Google or this forum. That piece is called, oil filter sandwich plate adapter. You can get it in about any brand; mishimoto, greddy.zonian91;2052678 said:Ok, what type of oil cooler kit is it? I might be converting my 7M-GE to a turbo and with that adapter, it could.
Thanks man, I got the part number from Napa for the o rings. Just haven't gotten around to ordering them or going over there. That spark plug gasket doesn't work at all, even if you buy new from toyota.atmperformance;2052710 said:ditch the spark plug gasket and o ring or crush ring the coolant ports, you'll be better off![]()
drogon;2052589 said:Finally got some time to work on her between jobs now between 2 haha. All I need is the clutch and she can finally go in.![]()
Currently it's free flowing to the cooler.akito;2052821 said:Clean set up, do you also have a temp switch in between or with this current set up oil is free flow to the cooler?
