Perico_Supra;1980145 said:The adjuster screw by the headlamp
That 'adjuster screw' just allows you to manually raise the headlight if the motor stops working. Not sure what would be causing your issue.
something else got bent look for damaged partsAbsoluteSpeed;1980158 said:That 'adjuster screw' just allows you to manually raise the headlight if the motor stops working. Not sure what would be causing your issue.
Perico_Supra;1980140 said:Went the mall on Monday, came out and found a surprise....someone hit me and kept it moving. Quick question, the driver side headlamp now has a mind of it's own going down then back up when i turn my lights on and it doesn't come all the way up like it's supposed to, nor does it go all the way down. Is it just a matter of adjustment with the inside screw?
slowma70;1980159 said:Well today i replaced the 2 square bump stops located on the hatch, Thankfully DM includes new screws, the original ones got stripped cause for some reason Toyota decided to put locktite on the threads. Results are that the squeaky noise went away making the Supra more enjoyable to drive..
Perico_Supra;1980140 said:![]()
Haha nash i'm glad you said something, I didn't feel like mentioning that fail hole. I thought at first it was of him fixing it. but now i want to take my finder off and check for a hole like thatNashMan;1980273 said:Holy rust hole batman that does not look good hows the rest of the car?
oh ps that not very safe since your door hing is held on by rust
that what happens when you have plugged drain holes
did i mention my driver door sags?Grandavi;1980332 said:Omg, that rust is scary 92 Ford style rust!
Now I'm worried about mine cause that's a bit if a hidden area
jdmfreak;1980354 said:True those things get everywhere lol
I used to go mudding in my truck at least once a week before getting my supra so when I wash my car the hidden pockets get special attention (old habits die hard) stuff getting built up over time have never been an issue for me so never crossed my mind![]()
