What are freeze plugs - guys says they keep blowing
Mk3runner
2,033
Nor Cal
hey believe me they do just blow out. probably improper install to begin with but still I seen it. thats how I got my mk3 so cheap..... also why its still on jack stands. but payday is tomorrow so I'll be able to get whats left to complete it. its a trip how the damn thing just popped out tho.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Improper size or installation could cause one to blow for sure. I keep forgetting that - it's a rare thing up here, virtually every machine shop that I've tried in Canada keeps both Metric and Imperial plugs in stock, and every shop can get oddball sizes in minutes from their parts wholesalers up here. :)
jason7mgte
Ok so I like the 88 tails
Dec 3, 2006
24
pa
I would say lack of maintance, they are all corroded from the inside out. Most likely the radiator and heater core are just about shot if they have not been replace already , headgasket is most likley ate up and ready to blow,check water pump also. Thats what happens when you don't flush every other year and 50/50 mix.
Unless of corse it was just rebuilt and they installed the wrong plugs thats highly unlikley though. yeah I know later responder
D
drumminforev
Guest
Still wondering if anyone has pics so i can see where i should be looking
buckshotglass
I love all your sounds.
This pic has a bunch of freeze plugs in it.
D
drumminforev
Guest
So those recessed circles are freeze plugs...why are they all random like that, and are they only in the block or located on the head also
Mk3runner
2,033
Nor Cal
I would put a up close pic with one gone.. but I'm in santa rosa at the moment. when I get back I'll get a close up of one when it comes out. I guess the old owner didn't maintain the engine at all. the amount of rust gunk water that came out when I pulled the water pump was just sick.
D
drumminforev
Guest
Bump for question...are they in the head also or just block?
Lucky for me, There was no freeze plug blown. It was just a BHG. The guy was a moron. It started, idled, and revved fine. So im replacing it as we speak, but those pics will still be cool for future reference.
ma70t
7mgte-s
Jun 7, 2005
141
va
before you start doing any mods on the car i think you should learn a lilttle more about the 7m to start with good luck man
D
drumminforev
Guest
I should "learn a little more". what does that even mean. You feel like i dont know some bit of info, so share it with me.
aljordan
LEADED FUEL ONLY
Jul 14, 2005
466
Indianapolis, Indiana
www.apeserver.com
Those plugs are casting plugs. You will NEVER have a block freeze and those plugs save the day. Never, ever. Those are there to remove the sand that the block is cast with.
Doorman plugs are just a hair too small. That's why they pop out. I've changed doorman plugs on one car to the toyota plugs. The smaller casting plugs from doorman are fine, but not the large one. There are 2 sizes for the 7m.
NeatOman
Never know enough!
Oct 5, 2006
233
Addison, IL
Yeah... but there called freeze plugs! lol
The correct name would be core plugs :icon_razz , freeze plugs are just jargon
ma70t
7mgte-s
Jun 7, 2005
141
va
drumminforev said:
Let me see if i got this right...they are holes in the block that are only there because some type of rods where there holding the block as its casted.
So why exactly are they called freeze plugs if burning hot coolant touches them
Does anyone have pics of where they are located so I can check them out when buying
yeah like you said your self here "do all cars have these plugs"
go do more research or just take time and learn a little more hahah dont be mad man im just telling you my 2 cent cause most mk3 that has been beat up by the old owner are money pit but hey do what you want its your money
i got 2 supra so i think that i would know hahaha dont try to play if you dont want to pay hahahaha
