Went to the dyno yesterday
te72
Classifieds Moderator
6,610
7
WHYoming
I'm leaning toward a gigantic A/R (relative to the engine size), given how late it spools. Still... that power level does seem off for the pressure level. Couldn't tell you why though. Perhaps MDC can chime in and provide some insight...
Torque
255
In your home
Those numbers seems very low for the psi like the others have stated. Check for boost leaks (maybe a leaking BOV). Just for reference, I made 471 with a 60mm turbo at 20psi on my 4 cylinder 1JZ (severely leaking valves in 5 and 6 resulting in damn near no compression).
Jostar
AEM powered 1JZGTE!!!
May 21, 2007
746
Chicago
Can you send me your CAL file? I want to see what timing they ran, to be honest, 25 PSI & 93 octane=boom..
NewGen
799
Norwalk, IA
I've heard the same thing. When I had my 2jzgte tuned the tuner said max on 93 was 22psi and 18psi on 91.
Dec 31, 2010
216
IL
Should have went 2J...haha just kidding nice power man, at 25 psi you should be high 500's. My 2J made 612 at 22 psi with meth with a MPT70, but only 677 at 29 as the turbo couldn't push it as healthy. (now have a T76 untuned) It did make less with the stock cams, see if you can save for some 272 regrinds! It would be well worth it! It would be even more well worth it to do a look over, do a leak down and the likes to see if you can awake some sleeping power! Congrats.
mk3tattoos
1,104
Bremerton, Wa
And do a compression check, just to make sure!!! Once you get it dialed in you should make over 500hp. I think you need another fuel pump, go with the walbro 400!!! To run 680cc you need more than just a walbro 255.....
1jzsupra88
Miami,fl
Well I just noticed I have a kink in the fuel line so Im going to do my fuel system all over again I'm going with a bosch 044 intank and steel bradied lines
Jostar
May 21, 2007
746
Chicago
wanna send me your CAL file? I want to see what timing they ran, I made 350HP at 10psi in my 1jz with a MP T70... now I am running at GT4276.. here is my e-mail.. artzors@yahoo.com
IndigoMKII
2,181
Madison, Virginia
I had a kink in the hard line coming from my FPR. I didn't know it til I checked my base FP and it was WAY over stock base pressure at 46 (33-40)
destrux
1,183
10
PA
The torque does seem low. I was going to just say it might be a dyno that reads low, but my 1JZ made that same 380 ft-lbs of torque at 15psi but with only 370whp. I'd also think maybe it's your ignition timing. The probably have it very retarded to get away with that much boost on 93.
BTW... my 1 year old son approves of your dyno chart.
