MK3Hitman21;1813418 said:I guess you don't see my question?
MK3Hitman21;1813412 said:What's the reading on the wideband at 5k rpms? Does it lean out or does it stay rich? Is there a boost controller hooked up
ifyouaint1sturlast;1813408 said:I think it's the igniter. Tach is directly linked to the igniter to supply RPM signal.
My vote is now officially igniter or a poor ground related to the ignition system.
figgie;1813454 said:breaking up under load and no load at 5k RPM
ignitor is an aftermarket unit?
Autodwell limiting control built into the ignitor? What are your dwell settings?
In short, sounds like not enough dwell time to charge the coils in the amount of time needed at that RPM.
MK3Hitman21;1813427 said:The wideband reading is important. Boost controller setup? Check your gain, set, and start boost on boost controller. But it sounds like a voltage drop somewhere. Make sure your alternator is good. Or a incorrect wire install. When a car won't rev past 5k the wideband is saying something.
IBoughtASupra;1813457 said:Thanks for coming in here Figgie.
There have been instances where the aftermarket coils can handle the power like stock coils can. SP in Chicago changed out Super Spark coils and other aftermarket coils with stock coils with over 80K and they worked better.
With what Figgie said I'd check:
-Plugs
-Coils
-Igniter
-Cam Sensor (I know you said it checked out fine)
-Crank Sensor (I know you said it checked out fine)
figgie;1813454 said:breaking up under load and no load at 5k RPM YES
ignitor is an aftermarket unit? stock ignitor
Autodwell limiting control built into the ignitor? yes
What are your dwell settings? ????
mkiiichip;1813701 said:How could boost control be the issue when it breaks up in neutral???????
IMO that should be shut off until the it runs well in the first place. Anyways......
I would like to redirect to this^ post. Although we have established a stock ignitor is being used. As far as i can tell there is only one question unanswered. This may not be the answer but at least we could move forward.
You have to weed through the BS sometimes, while andy was helpfull for getting figgie in here, him and hitman are basically useless otherwise.
mkiiichip;1813701 said:You have to weed through the BS sometimes, while andy was helpfull for getting figgie in here, him and hitman are basically useless otherwise.
IBoughtASupra;1813835 said:Chip,
What is your problem? What posts in this thread were useless with incorrect info? I agree with the boost setup not having a factor but did you see my post saying anything that it did? Please point out the issues with my posts here and how I am pretty much useless. Don't drag your anger from you own thread, I apologized for that in your thread, and left with no future comments planning to be made.
IBoughtASupra
On the stock ECU, a customer had broken ground wires on the two tabs that bolted to the intake manifold. After fixing that, the break up the car had went away. Since I seen it happen first hand and these harness' are not getting any younger in age, it could have been a possibility so it just made sense to rule it out, no?
The comment about alternator wiring was incase he wanted to check it after reading hitman's comment.
figgie;1813831 said:IBoughtASupra
In this instance, it is not about power handling as it breaks up with no load. This points to dwell settings or ignitor is lacking (bad ground, horrible power conncetion, dirty input signal etc).
To the op.
Dwell settings. I can not answer where that is in the AEM system. With that said. Since you are not running CDI, dwell setting MUST be set. This is not optional in a standard ignition system. The 1jz ignitor never autodwelled.
Unknown gap. For all intents and purposes, you could be runnin a .5 GAP and not even know it! Don't eye ball, MEASURE.
IBoughtASupra;1813852 said:Only grounds needed would be:
Chassis Ground To Negative Post
Engine Block To Negative Post
There is one from the firewall to the head but many members remove or it's been damaged throughout the years with little to no effects.
Figgie,
Yes, that's why I said it doesn't hurt to check them, a visible check and multimeter is all that is need to verify they are fine plus they are easily accessible being on the side of the manifold.
OP:
Did you try a different igniter yet? I know you got the AEM from 70Dreams, correct? I have the same one, what happened to the base map that was initially loaded?
figgie;1813831 said:Dwell settings. I can not answer where that is in the AEM system. With that said. Since you are not running CDI, dwell setting MUST be set. This is not optional in a standard ignition system. The 1jz ignitor never autodwelled.
mkiiichip;1814053 said:So the ignitor does not set its own dwell? I thought it needed like a 3ms signal at all RPM's, and it set the charging dwell automatically?
OP what are your current ignition settings?
Checking grounds is fine, but they have been checked, and i think this setup has run in the past, just with a different ecu? This is what makes me think this is a settings issue.
