well ive stripped the rear of my car.
Silent Smith
Jerk.
Nov 30, 2005
59
Mississauga
Could be wiring for factory subs?...
If you end up finding a decent shop or decide to go through with doing yours let me know. I have to do mine and seeing how your doing it or giving you a hand will probably help me on mine.
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
instead of taking out the rear stuff you should pull your int. out and remove the sound deading you will lose about 46lbs just by doing this. believe me i did it. and its not that hard i used a brick hammer
BTZ
Burnaby
I dont remember my 86.5 having sound deadining material just below the rear speakers. strange....
rakkasan
Currahee!!
Fort Campbell, KY
Cryo,
If your rusted area is the wheelwells, use metal instead of fibreglass. Reason being is that fibreglass will shatter is your tire tosses a rock whereas metal will bend.
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
i pulled the computer cable out. it was really loose. soo as it came out i knew why. i thought i broke it but it was cut at the end... now ill never find out where it went ...
shaeff
Kurt is FTMFW x2!!!!
11
Around
i believe that's for a car phone. my car had it, and it also had four holes drilled in the passenger side dash, near where the passenger's left knee would rest against the center section. those four holes are the mounting points of the carphone. (i no longer have them, as i switched dashboards) and a supra in a junkyard near me has them, and still has the phone... well, before it got crushed anyway...
-shaeff
