WEIRD WHIIINING SOUND.........?HELP?
marlonvip
Supra -only way to fly
Sep 2, 2006
189
Denmark
HI Guys,
after I have driven my car 7mgte 88 and I park it,
I heard this constant loud whining sound from the back of the car??
This is after I have turn of the car..........
Could it be the fuel pump (oem)??
Any thoughts:)
thanks
Marlon
turbo4toy
208
Los Angeles
In the engine bay in the diagnostic box use a copper wire or something and connect port B+ to FP. This will allow you to run the pump briefly without starting your car to see if you pump is working correctly. If it makes the same whining sound you were talking about you know what it is.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
umm rear diff on it's way out i think that or your center support bareing eather or chould be causeing this
ViR2
Supraniac
May 20, 2006
932
Lithuania
www.hpaddict.eu
it could be anything, event a small exhaust leak ;) Could u describe the sound u're hearing a bit more in detail? What side is it coming from? Is it hi-tone or low-tone?
marlonvip
Sep 2, 2006
189
Denmark
yeah its after I shut of the car , NOTHING IS ON and then I can hear this sound -
its like a constant high pitch sound - cant really explain it much closer:)
So its not drivetrain or diff -
Maybe fuel pump, Ill try the diagnosis box test:)
thanks FOR THE MANY ANSWERS
MARLON
tte
Breaking In - in progress
Northern California
Check the motor in the rear hatch for the power antenna.
When I bought my car, I found out that the motor for the antenna was unplugged. I plugged it in and it made the same whinning sound. Probably thats why the previous owner left it unplugged
Havent had time to fix it so I just left it unplugged.
Cheers,
Roy
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
its probably a baby dinosaur
jimi87-t
1,127
Colorado Springs
Marlon
Slap the bitch sitting in the back seat and tell her to shut the hell up!
Actually, I would think it would be the power antenna also.
89Turbo
804
Portland
MARLON
antenna
