When the car is warming up it has a teeny high idle like its supossed to, to warm up. sometimes it will idle fine afterwards until randomly it will drop to 300 then bounce back to 500. it hovers around there for a bit but will keep fluctuating and sometimes die. however the car still pulls real strong @ WOT.
oh and when the idle problem is happening if i hit the gas to keep the RPMs up it sounds like its missing.
the problem started when i put my 550's and lex AFM in the car. i've swapped out the AFM electronics and tested w/ a multimeter, no luck. got a scope to check injectors, they're all firing. swapped out spark plugs, that didnt help. tested IAC, TPS with multimeter, they're good.
im getting code 31, the AFM code. i know the electronics are good cuz they worked on the stock AFM and i tested w/ multimeter. even swapped out my IAC, and CPS for known working units from my other engine. timing is set @ 10 BTDC w/ the diag block jumped. puel pressure is 28-30 @ idle set w/ aeromotive AFPR.
if anyone can think of anything to help me out, please done be afraid to throw ideas out there.
[cliff notes]
installed 550cc injectors, and lexus AFM now car has intermittent rough idle problem.
[cliff notes]
