I run 50/50 and have done weeks, months maybe of research and these are my opinions based upon information i have found and considered.
gottadiesel;1653004 said:
IJ, please correct me if I am incorrect, but methanol is a fuel, thereby if you are adding fuel beyond what the ECU is telling the injectors to flow, then you will run richer than without. I believe the water is simply to keep Cylinders cooler... thereby reducing the risk of denotation.
Will water alter the WB sensor reading? I am assuming that all of the oxygen in the water would be used no different than the air. Do the EGT readings play a bigger role with verifying that the water is doing it's job?
Methanol is a fuel but it burns in an entirely different manor then gasoline. Water is not a fuel so therefore it will pass threw an engine without any change to the A/F ratio as there is no chemical composition change on its journey.
IJ.;1653023 said:
Methanol has a different stoichiometric value to Gas, Lambda 1 = 14.7 AFR for gas and 6.4 AFR for Methanol so any reading on a Wideband is no longer going to be accurate as I stated earlier.
This is where it gets tricky for tuning as we discussed in PM's. I will discuss at bottom.
CajunKenny;1653277 said:
The AEM WB's have a Lambda Reading option.
Both readings are gathered the same way, the only difference between displaying Lambda and A/F is the scale it is displayed on.
Blackdawg;1653451 said:
But there are some weird things in this thread that i dont really agree with.
Second i seriously am curious as to why you ran 6 different injectors for water?? AEM clearly states that the nozzle on there kit should be before the TB...i think like 12-18in..not sure on that. But to me that just seems way to much..
but the fact that methanol is acidic and can damage aluminum is scary..
He was running direct port injection. It assures the same volume of injection is delivered to each cylinder. Methanol is corrosive but only in pure quantities. I have researched aluminum tanks and have never seen an actual report of an issue. Running 50/50 should dilute the methanol enough to make it stable with aluminum.
Heres what i have gathered and is my opinion on the topic based upon information i have gathered.
First you need to look at the physics of what happens in a combustion chamber. When the piston moves up on compression the fuel air mixture is compressed. When a substance is compressed, the heat in that substance occupies a smaller space then before therefore the temperature rises.
If your compression ratio is 9:1, its temperature should rise 9 times that of witch it started (for argument sake lats assume theres no outside loss) before it was compressed. Because of this, water is an excellent additive as by half way threw compression it should have been heated enough to convert to steam. When the water goes threw this phase change it absorbs large amounts of heat.
Obviously water should be there somewhere because of how useful it is in making a harsh environment more tolerable for lower octane fuel.
Methanol on the other hand is flammable, higher octane then gasoline and breaks down the surface tension of water so it can separate into a finer mist and blend with air more efficiently.
This all sounds great but adding methanol requires more then just a good measuring cup. Just as running E85 requires a different air fuel ratio (~9.4:1 IIRC) as opposed as straight gasoline, Methanol (as mentioned) has a different stoich (6.4:1) AF ratio and under power (4:1) AF ratio.
Because of this the target AF Ratio changes due to the change in fueling. In order to find out what target AF ratio you should adjust your tune for, you need to know the Percent of fuel being consumed by the engine that is methanol and gasoline.
If you find that 10 (for round numbers sake) percent of the fuel your engine is burning is methanol (without water) then you need to calculate a new target ratio. Say your original target is a safe 11.5:1, and you know methanol's safe AF Ratio is 4:1, the math goes like this.
4:1 or 4 x 10 = 40. 11.5:1 or 11.5 x 90 = 1035. 1035 + 40 = 1075 / 100 = New target AF Ratio of 10.75:1
This is very easy assuming you can easily find out exactly how much of each fuel the engine is burning. Problem is, thats not so easy.
Any questions or corrections feel free to discuss.
