i found a built shortblock i haggled for 1400,
89+block, eagle, wiseco .20's ceramic/teflon coated, arp everything, new oil pump, decked .6mm, balanced 6m crank (lighter than 7m+even lighter when balanced) king bearings, all new seals/gaskets/freeze plugs (which will get ditched in the "going over" process, but still)
parts alone are well over what i paid for it, 1600...then machine work/assembly will probably cost another 1k at a reputable place (block only!...expect another 2-600 for the head, depending on valve angle jobs, etc) so, to do it yourself youre looking at around 3k just for the ground work and thats maybe if you know a guy that knows a guy, could be more, could be less.
then youll need the basics to help with future assurance...mostly anything thats difficult to do later, invest and do it now!
full gasket set/freeze plugs(100+), performance timing belt (greddy for mine, retails about 150+, got it for 75) arp head studs(130+..mine-75 bucks), head gasket (calculate needed size accordingly! mine is hks 3.0, 250 shipped) clutch/flywheel, arp flywheel bolts, and i know im missing several other big ticket items.
race/mild port job/basic gasket match for head and manifolds (lots of your own time and about 50 bucks+ for the tools/attachments)
various hardware, clamps, hoses, rebuild kits (did my cps, power steering pump, starter and alternator while i have it all out)
if i was paying someone to do all this im looking at 5k+ for everything...really im at around 2400+ including things i was missing like upper timing cover, coil cover, broken gauge cluster, broken front bumpers etc...
once you have the basis there and broken in, all is well, THEN you can start shooting for power...factor in plenty more money to get 600hp but atleast at this point its all just bolt ons and relatively simple to install...budget and tuning will make this the more difficult part of this build.
im in the exact same boat you are, 600 is my overall goal with pump 93/95 and meth injection...maybe e85 in my future will bump that up OR will get me to that 600 mark if i dont hit it with pump.
im no pro, this is just how ive gone about things...there are plenty of members here that will point you where you need to go, just like theyve helped me. i also need to give props to most members on supraforums as well since its my main forum.
budget/sell toys/take a loan/work on your knees, whatever it takes to get it done...im done spending money for now but atleast its done!
