Thats mint thanks:icon_biggMDCmotorsports said:BTW heres every thing you need to know about the Walbro!
Thanks John Lunsford!
http://www.jblmk3.com/id82.htm
Afunk said:just a hole to the block
empera said:so with a fuel pump and FPR i wouldnt need 550's? if im plannin to push 400-450?
shaeff said:550's are good insurance. the stock 440's MUST be AT LEAST cleaned (flow tested, too) in order to push 400hp. my question to you is:
why risk burning up your motor for a set of $350 injectors from RC engineering? the 440's wont support 500hp. they'll be far past their duty cycle to be running safely, and you risk injector failure.
-shaeff
