Walbro Fuel Pumps
shaeff
Kurt is FTMFW x2!!!!
10
Around
just get a rubber hose and bypass the entire setup if you'd like. if you remove the j tube from the block, then there's a gaping hole in your block. :( (back from when the origional casting used a mechanical fuel pump, i believe)
-shaeff
mcpcola
7M's = Peoples Champ
Jul 4, 2005
428
Greater Gulf Coast
Damn i wish i would have know this info earlier about the Return line as i have been running rich since the pump was put in. Well the car has only seen maybe 30 minutes of real drive time.
shaeff
10
Around
empera said:
so with a fuel pump and FPR i wouldnt need 550's? if im plannin to push 400-450?
550's are good insurance. the stock 440's MUST be AT LEAST cleaned (flow tested, too) in order to push 400hp. my question to you is:
why risk burning up your motor for a set of $350 injectors from RC engineering? the 440's wont support 500hp. they'll be far past their duty cycle to be running safely, and you risk injector failure.
-shaeff
smurfmods
26
New Orleans
-shaeff
Yeah, from what I understand a failed injector could lead to a failed engine...
smurfmods
26
New Orleans
What's the most HP i can expect to get out of the stock ct26?
I feel like I'm pretty close to reaching the limits of my turbo with my setup.
