walboro fuel pump
AZN MK3
341
Now in the U.S.
ok i have an 87 supra which is n/a and well i've seen alot of walboros for sale... ok my question is, is there any difference between the n/a walboro and the turbo walboro.. and if not which one do you guys think is best.
Mods are pretty much a stock 1j with just a boost controller and a 3" exhaust. trying to upgrade fuel before i go tune... thanks guys
Nopaint
110
Jan 30, 2007
172
GA
I think they only offer one type of Walboro... and if they do offer two different types which I've never seen before, get the Turbo one..
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
Wait, so you had an NA, that you swapped a TT 1JZ into?
The way you word it, it seems like you have a NA 1J
Either way the Walbro 255 is a universal application, if you get the kit for the Supra it will work on Turbo or NA.
AZN MK3
341
Now in the U.S.
oh sorry no i had a NA supra and then i swapped in a 1J in it... sorry for the confusion... and thanks... just wondering thats all, and looking around for who has the best price on 'em.. so thanks
Supratrbox2
Damnit
Jul 27, 2005
133
South Jerzey
I ran my 1j on the 86.5 na pump for a year and a half and it was ok. It leaned out alot in the upper rpms and it was noticeable. Still would get up and go:biglaugh: .
Rich
tunin' tha beast
Jun 2, 2007
319
the netherlands
There's many walbro's, not just one:
GSS242, GSS250, and GSS278 are 190 lph models
GSS307, GSS315, and GSS317 are 255 lph models
GSS340, GSS341, and GSS342 are 255 lph high-pressure models, also called the 255 lph HP
You want the GSS341 like said above.
AZN MK3
341
Now in the U.S.
86_sports_1jz said:
there should be only one made, how does the 1jz run on the n/a fuel pump? just courious
feels nice but towards higher rpms it tends to feel restricted... i was looking at the walboro 255lph.
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
Get a bosch -044 :)
MKIV TT pump is also a drop-in upgrade.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
SuperSupraKid said:
you should consider getting a new afpr if you are thinking about upgrading to a 255. ?? ?? ??
along with bigger injectors and properly sized lines. You may also want to look into modifying the fuel rail if neccessary (feed on each end return in the middle
AZN MK3
341
Now in the U.S.
annoyingrob said:
Stock lines and rail can support a large amount of power before needing to be modified.
oh really? and how much is that... im really just shooting for say... 350 to the wheels with just upgrading my fuel pump and injectors... with tune of course.
