IJ.;1087740 said:Yes but if ANYTHING goes wrong that head is coming off
Done this in the past as as a security blanket I pull the piston down a bit and carefully feed some good quality non fuzzy rope into the cylinder then gently bring the piston back up to TDC. (safer than using a compressor)
Kckazdude;1087742 said:I have always used the air hold method myself. Am interested to hear the safer theory however.
Kckazdude;1087756 said:I understand feeding the rope into the cylinder, just not the safer part. Unless safer as in there is a physical retainer keeping the valve seated unlike with air. I have dropped a valve once doing seals with air. Took me an hour to get it back in without pulling the head. Of course that was a 5S-FE Camry also.
IJ.;1087797 said:For instance in a multivalve engine like ours you get all cocky and pop the spring off one intake and decide to pop the other off to save time.....
As you pop the 2nd set of collets the valve unseats for a second and this is enough to let the other free valve slide into the cylinder.... DOH
IJ.;1087815 said:Didn't ya just love that sinking feeling as it slid in![]()
gtsfirefighter;1088256 said:giggity
I used the nylon rope method when i changed out my valve stem seals....worked great.....IJ.;1087755 said:Nylon will work ok
You just want something that isn't fluffy/fuzzy so it doesn't leave crap behind when you pull it out.
Rememeber NOT to go nuts on the breaker bar on the crank you just want enough rope cushion to stop the valves falling in.
