Valve Spring Replacement w/ Head on ?
ronnie4
136
Huntsville
What valve spring compressor did you guys use? I can't seem to find one that will fit between the spring and the channel in the head.
ronnie4
136
Huntsville
GrimJack;1174907 said:
I just built my own by using a large C-clamp and taking a dremel to a small section of pipe.
Were you able to do that wit the head on? The only type that I know of that you can use with the head on is the type below, and I haven't been able to find one that will fit in the head.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
No, this was with the head off. With the head still on, I use a long piece of pipe that's been dremeled out, and push the spring down with my weight. Then I get a buddy to pull or replace the retainers.
Haven't figured out a good way to do it solo with the head still on.
I have the one that ronnie showed, I had to bend the claws to work with the head, but I didn't do the reassembly and i don't imagine it would be fun...
turbo87targa
482
colorado springs
Is it easier with the cams out aswell? Cause I'm gonna be doing my cams springs and shims in a month or so and don't want to take off the head again lol cause if I have to I'm just gonna have the head ported and pistons rods and bearings done.
jdub
Feb 10, 2006
10,730
Valley of the Sun
