hey i have valve rattle when i start my 1jz when cold ,is this normal ? im running moble 1 synthetic and it does it even after a fresh oil change . should i reshim valves ? it clears up after 3 or 4 seconds.
shit now your scaring me. the sound is comming from the top end. ill double check though.annoyingrob;1191934 said:Are you SURE it's the valves? Sounds like bottom end to me. If your bearing clearances are out of spec, your rods will rattle around on the crank until pressure builds.
aphxero;1192684 said:I had a similar thing on an old motor. Then put the head on another motor it was still there.
I've had a friend who's exhaust cam seized in the head. Maybe oil passages are clogged? I'll bet accusump would stop it. Still doesn't fix the problem haha.
dogdrake;1239382 said:hey sorry for not posting back i found out i have a puralator filter do these have a anti drainback valve?
