valve breathers vs. catch cans
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
lol i didn't blow no seals out (yet) but i hooked mine up wrong recintly when i put my n/'a valve covers on and relized i had to mod some stuff. i hooked it strait to the tb and each time i boosted i had 10psi in the crank case, then engine vaccum. nedless to say she was smoking!
shaeff
Kurt is FTMFW x2!!!!
10
Around
^ yep. i've got the thick steel wool in my greddy catch can. :)
-shaeff
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
That's what I was thinking of doing, I bought the OBX knock off version of the bigger catch can a long time ago not knowing there weren't any baffles in it and it was just hollow... I'm gonna be buying another one it looks like ;).
bentandbroken
Lackluster
Jan 17, 2007
66
i wish it was paradise
The only reason I can think of not venting to the atmosphere is if you drive on a track. I know a buddy of mine that just clamped two hoses to the PCV ports and ran them over and down beside the intake manifold. He had a Greddy catch can but couldn't get it plumbed correctly and instead did the above modification. Personally, I plan to just use the hoses. KISS-keep it simple stupid; plus it's a lot cheaper.
P.S.- I'm not saying doing is the best way to perform this modification.
5uprahboy
343
Auckland
Have you fixed the smokey problem now?
Sawbladz
1,727
Oshawa, ON, CA
Im not sure I follow you 100% but it seems like you are saying that you just have some lines hooked up to your PCV that allow the oil/gases to go to the atmosphere? If I understand correctly then you should re-read this thread. That system you described, with open hoses, has no vacuum and would therefore not allow the PCV to function correctly. If I misunderstood your post I'm sorry but I doubt it.
supra90turbo
shaeff is FTMFW!
32
MA, 01440
If he's describing them ending at the intake manifold, you're right. He did it wrong.
If he extended them down to the oil pan or transmission, he did it semi-right. Road draft is the term, and it's still used on over-the-road Semi's to this day. At work, our 2004 Chevy C4500 ramp truck with a 7.8L Duramax even has one.
