Vacuum help
mk3-4-me
669
Milwaukee, WI
so i just got my car running after a rebuild and im still working on getting it ready to drive.
My car right now idles real rough at around 1k for a little bit. When its idling at 1k my boost guage stays around 3 psi of vacuum.
After idling there for a little bit, it starts to rev its self up to around 2.5k with the vacuum going down to around 7 or so.
when i hit the gas it goes up to 3.5 k and drops down with the boost getting to 3 psi.
what do you guys think?
bozosoku
CT
Vacuum leak ? Idle should be 650 rpm with minimum 7 psi vacuum according to TSRM, my vaccum at idle is 18 psi.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Are you using an actual vacuum gauge (not the dash gauge) and are you sure its plumbed into manifold vacuum and not ported vacuum? (make sure its not using a throttle body port to measure vacuum, make sure its coming directly off the manifold)
mk3-4-me
669
Milwaukee, WI
Ya its aftermarket and i have it connected to the 2 vacuum ports for the egr line on the top of the throttle body... So where do you think i should put it?
89supra7mgte
797
colorado
Just for reference, vacuum is inhg, not psi. got a little confused looking at that. I would check all ic pipes. as well as relocating gauge to back of manifold. or tapping into the boost psi line, which comes right from manifold
mk3-4-me
669
Milwaukee, WI
so i put hooked the guage up to the back of the manifold like you guys said, and its still the same... I get about 7 inHG of vacuum.. but wen the engine revs its self up to 2.5 k and back down (keeps doin it over and over) the vacuum goes down to about 15 or so.
shouldnt the vacuum get closer to boost when the egine rev up higher?
i mean when i hit the gas it revs up to 3.5 and stops, but the vacuum goes up to about 3 psi of boost.
I just redid IC piping, checked for bad vacuum lines and that didnt help. It idles really rough barely staying alive. I timed it and got it to 10* btdc.
My oil presuure guage also reads about 43 psi when it idles... I read somewhere that it should be 4.3 psi.. what do your guys oil presuure guages read at idle?
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Do you have any codes? Even if the check engine light is off, you can have stored codes. Hook up your jumper and check. Your vacuum should be anywhere between 18-22inhg approximately at idle, but that is assuming you have a steady idle. Is it smoking or anything unusual out the exhaust? You aren't going to make boost just revving the engine up, there has to be a significant load on the motor to make boost(driving). Oil pressure will be higher when it is cold, 4.3 is the minimum spec for a fully warmed up engine at ~650 rpm.
mnracer550
160
Duluth, Minnesota
with that reving to 2.5k it sounds like the tps sensor. mine did that when i forgot to plug it it in once. get some carb cleaner and start spraying down vaccum lines and ic piping and anywhere u could have a vacuum leak to try and find it. when u heard the engine rev a little that where the leak is.
---------- Post added at 10:51 AM ---------- Previous post was at 10:50 AM ----------
oh, and mine usually sits about 20 psi at idle and around 40psi wot at operating temp
mk3-4-me
669
Milwaukee, WI
ok so i got the codes:
24 - intake air temp sensor -- what is that?
31 - AFM signal -- need replacing if that codes comes up??
41 - TPS -- replace?
51 - Idk why i have a knock sensor code cause they are both in. Do those go bad?
what do you guys think? replace everything? id rather not if i dont have to. How much is everything do you think?
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Sounds like you have your AFM unplugged first of all, considering the intake air temp sensor is inside of the AFM and uses the same connector. Go make sure you have a good connection there. Then, go into the tsrm and find the TPS adjustment procedure and verify your TPS is good, has the proper adjustment on it, and is plugged in with a good connection. Worry about the knock sensor codes later once you get the thing to run right.
