Vacuum/Boost leak unable to find
mk3na-t
7
Akron
After replacing a head gasket I have now encountered this problem. My vacuum gauge reads 18in hg and when I hit 8psi of boost I hit fuel cut. Which to me sounds like a vacuum/boost leak but I have done a boost leak test on it and have been unsucsessful on finding it. So from there I went to my shop and picked the smoke machine and then smoke tested my intake system and once again unable to find any leak. PLEASE HELP ME!?!?!?::aigo:
mk3na-t
7
Akron
Nick M;1344371 said:
Must be magic. Do you have a code 34? And you won't see a small leak without pressure.
Yes I do have a code 34. And With an evap smoke machine you should be able to detect a small leak.
8,894
An evap smoker isn't exactly the best. If you have a small hole, it will be closed up until positive pressure is put in the intake. 18 inches of vacuum isn't actually that bad. So the hole is very small.
paradox616
472
Melbourne, Australia
deoderant can :)
or carby cleaner, spray near manifold and listen for rpm increase, its how i found my leak...
on my new motor i just took the time to coat all the paper gaskets in high temp silicon to fill in any small imperfections to avoid this in the future.
