mk3 bamf;925352 said:v-mounting is good for sorter IC piping and the IC and RAD get equal air flow . so how is it not a good idea?
Because the Supra does not have space for it.
RX-7s, 240s, and other cars with room can get away with it because they can do it without having to run a significantly smaller intercooler or a ton of cutting.
Look how much room there is in an RX-7 engine bay
And then a Supra
Where are you going to put IC and radiator in a Vmount without serious cutting and downsizing your IC?
Run a larger radiator and intercooler instead and you won't have a problem. Your Supra doesn't have a problem with overheating does it?
