I have personally never used it. It is pretty simple though. You apply some to a surface, torque everything down, dissasemble, then check the plastigauge against the reference card. From my understanding it is not the best method to use on our motors. A good set of gauges and calipers will be for more accurate, and yield better results. You dont want any bottom end bearings too loose.
