Greek;1795332 said:Would you mind making a write up of literally everything needed, possibly with cost included? I'm at a standstill between rebuilding a 7M or swapping for either a 1UZ or Chevy 350.
yes i used a 92 pickup brake boosterGreek;1796024 said:Did you change out the break booster? I've read that was needed.
Any changes to the fuel system? New pump? New lines? Mechanical or electrical fan? Did you find headers that fit or have them fabricated?
PureDrifter;1796045 said:use SC400 headers, and usually (though not always?) you have to swap the brake booster for a smaller one.
i've been gathering parts lol. if you ever plan to boost it pick up a '95 and earlier SC or '94 and earlier LS block. stronger rods+not interference.
if you want it to clear the subframe properly stick to an SC sump. (rear sump)
yes im running a w58 and no there are two different adapters each transmission has its own, but they use the same bellhousingGreek;1796057 said:You're running with the W58 correct? Will the R154 bolt up with that adapter plate and UZ bellhousing?
taka21;1795863 said:for this swap i used
97 1uzfe
engine harness came with it
ecu came with it
ignitors came with it
1uzfe swap kit poly motor mounts
quantum auto w58 adapter plate
steel flywheel
clutch
pressure plate
new flywheel bolts
braided stainless clutch lines
spacer for the hydraulic throwout bearing
1uz auto bell housing
howe throwout bearing (no longer recommended due to its high fail rate) use Quarter Master 721-100
i think thats everything that i used and overall i spent about 2k on all that
