Some cool new turbo innovations have recently become available, and I am just about to buy a new turbo kit. I currently have a stock 3.0L 7MGTE with BPU mods supporting up to 500+ hp, but currently making 393rwhp on a basic upgraded CT26 turbo.
The car is street-driven 99% of the time, and I'm interested in 475-550 rwhp on the street with meth injection, and the fastest spool possible. I will be running the Sound Perfomance quick spool valve for even faster spool (info here: http://www.sound-performance.com/p192/Sound-Performance-Quick-Spool-Valve/product_info.html)
I'm also looking at using one of the new billet turbos, since the lighter weight aluminum compressor wheels are shown to spool much faster.
So I will have 3 things on my side to support some very fast spool:
SP T4 valve
Ball bearing CHRA
Billet compressor
Typically, a lot of supra owners might simply choose the GT35r, for a good balance of fast spool and top end power, often with a .63 or so A/R, making around 500hp. I was thinking of going with a .83 so that my effective A/R with the valve closed would be around .4 for fast low-rpm spool-up, and offering more top end power. Forced Performance offers a modifed "HTA" GT35r with their own higher flowing billet wheel and compressor housing that has become very popular with the 4-cylinder crowd, with lots of dyno sheets out there showing faster spool and more power than the GT35r. Precision also makes a billet 62mm turbo, but so far does not seem to have one with the GT35r-sized 68mm exhaust turbine with a divided T4 housing, only a 62 or 76mm turbine. I'm thinking this HTA turbo with the SP valve should really outspool the GT35r and make up to 550hp? It is rated to flow 70lbs/min, compared to the 60-65lbs of the GT35.
Also, the HTA billet turbo is available with a 86mm (exducer?) compressor size instead of the 82mm on the regular HTA turbo and GT35r. It is rated to flow 80lbs/min compared to the 70lb of the HTA and 60-65 of the GT35r.
Just thought I put this info out here to hear some feedback from you guys, since this combination has never been done before on a Supra as far as I know. Any thoughts as far as possible negatives? Which specs would you choose? I don't see how it can be too "spool happy", considering how the stock turbo is so small and fast spooling. Could there be any potential surging issues with the valve closed? Should I consider a 1.0 A/R? Or even look at a billet GT37 style turbo? This is my first turbo purchase, and I'd like to make the right choice the first time.
My goal is to do forged internals/cams/porting/oversize valves/standalone at the same time, but we'll see how rich I am first, and may have to do that later, and be careful to not blow the stockers.
(P.S. My car has room for 345 drag radials in the rear. I think it would be awesome to hit full boost very early in 2nd gear with 500-550rwtq.... and fully hook up! How much power could a drag radial of this size put down, by the way?)
Cheers - Brad
SP T4 valve
Ball bearing CHRA
Billet compressor
Cheers - Brad
