Under hood cleanout
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
stock radio:)
under hood
wheel spacer
back carpet
minimal rust in spare tire bay
toyota tool bag
passenger seat
driver side floor carpet
driver seat
KPH?!??!?!??!??!??!??!??!?!??!??!?!?!??!
really???? i mean its an awesome looking cf custom gauge cluster ... but really????? KPH
ugg i am gonna have to do math as i drive
LOL
and its got tokicos
destrux
1,183
10
PA
I'd swap them out for some stock gauge faces, rather than always knowing how fast you're going in canada. That's a pain, I had a car with KPH gauges once.
Car looks pretty clean though, good find.
If you want to really clean up the engine bay, just start taking out anything that you don't need. Depending on what you want to keep, there might be alot of stuff that can be removed.
The stock boost gauge is mostly useless to anyone who mods the car, so you can ditch the underhood sender for it (and stick a n/a volt gauge in the cluster instead). The fuel pump speed relay and resistor can also go, you can hardwire the pump to run full speed all the time and take the relay/resistor out of the car completely.
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
Car looks pretty clean though, good find. The fuel pump speed relay and resistor can also go, you can hardwire the pump to run full speed all the time and take the relay/resistor out of the car completely.
Thanks...:D. I will be running a Walbro j tube removed and a aero fpr will that be a problem ???? Maft pro on map
Sent from my C771
shipkiller
398
Quebec
canada and the rest of the world
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
jdmfreak;1810243 said:
i am interested in that bracket as long as its not gonna interfere with anything .where does it go in the wheel well?? .....
jdmfreak;1810262 said:
Ruin the rear end with wheel spacers??
I Have heard something like that before .... but how are they different from offset ??
jdmfreak;1810332 said:
So i can hide half my harness and maybe my fuse box and get rid of cruise control....still debating that last 1... heard of people switching coil packs to coil on wire ... are there any advantages/ disadvantages to that???
jdmfreak;1810557 said:
Thanks...:D. I will be running a Walbro j tube removed and a aero fpr will removing the fuel pump relays and leaving them on be a problem ???? Maft pro on map
Sent from my C771
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
thank you very much by the way
... i forgot to ask do you know if its easy to swap just the gauges or if i would be better off finding a na cluster????
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
mkiiichip;1811924 said:
Spacers are fine, as long as they are installed correctly.
ok thanks:) that will save me some coin right off the bat
How can u screw that up ?)? Bolt em on , torque em down...attach tire... right???..... just checking because I have never used any before
Sent from my C771
mkiiichip
1,434
WI
There are different types of spacers, some of them bolt on and provide new wheel studs, some are just spacers. If theyre just spacers, and you dont have enough stud length to properly fit the lugs.... well, you get the idea.
