Great build man,
Do keep in mind though that just as pressure ratios multiply when you compress air twice, density ratios also drop because the air is being heated twice.
I'd bypass the supercharger once the turbo is spooled and stick to a single compressor up top ... especially the way you have it setups (the supercharger has no intercooler after it to boost the density of the air).
Check out our
turbo density ratio calculator...
In our calculator we have a thermal model that is arranged for sequencial twincharged setups
This allows you to quickly compare the difference between different efficiency chargers and between having the supercharger bypassed or not , and what effect that has on both your density ratio (your final power figure at a certain boost level) and as well on how close you are to auto-ignition ... which is something important to keep track of when you twincharge
Would love to do an article on your car... be in touch and awesome build
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
