turn down the boost boys and girls: pics
figgie
Twin Cities, Minnesot-ah
20 psi on what?
the ct26?
if that is the case all that is pushing out is super heated air anyway. You could have had C16 in there. it still would have detonated no thanks n part to the pea shooter going way above its working zone.
Suprapowaz!(2)
2,870
San Antonio, Tx.
Broken ringlands. Same thing happened to me when I missed a gear and over revved while at the dragstrip. Only I wasn't running cat pee for gasoline.::hah::
You live and learn.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
OP, you have no business with this car if you can't run the proper fuel. Blaming the pistons is about the most ignorant statement I've EVER heard.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
Who;1495108 said:
So much truth above.^^^^
On a side note "Winter Blend Fuel" gives you less mileage or it has less energy. It makes me wonder if that just makes matters worse when using low octane fuel.
You get worse mileage in the winter because colder air is more dense than hot, requiring more fuel burned per unit volume.
Also, at only $0.20 more per gallon, wtf are you thinking? Thats $3 more per tank. That savings looks pretty good now, hey?
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,778
13
Long Island, Ny
wiseco7mgt;1495090 said:
Manual boost controllers are shit quite frankly, you'd have been better off keeping stock boost if moneys tight.
Depends on the controller, mine has been very reliable. Mine also defaults to wastegate spring if it comes apart though.......
3.0 GT
2JZ Holset Mafia
Nov 30, 2008
381
Franklin, Tn
figgie;1495149 said:
20 psi on what?
the ct26?
oh sorry to mention its a 57trim ct26
kotu100
1,899
Easton, Ma
wow, spend all that money on mods, and can't spend an extra $5 to fill with 93.
and if you MUST use 87 dont boost at all.
Nghty89
Zombie Chicks Are Hot
Mar 26, 2008
978
7 Cities, VA
57 trim at that... on 87....
Sorry man, but that's one of those things that makes me stop and go: "Do you really understand how it all works?"
Good luck with the rebuild.
turbo87targa
482
colorado springs
kotu100;1494959 said:
why's that?
i doubt i'd ever change my mind, i've used 93 since day 1 on all my turbo cars.
Cause 93 doesn't exist up here....Last place I saw 93 was in Kansas on my way from buying the sup in Tennessee :(
unleaded: 85
mid: 87
premium: 91
but my car has never seen less than 91.
suprafanatic
1,607
Greenwood, IN
even if you were only boosting 14psi.. anything less than 93 should be an obvious NO. either way that really sucks that happened.. get her fixed and back on the road, maybe get a better boost controller and keep 93 in it ;)
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
san supra;1495160 said:
now this does suck but did it feel awesome right before the boom?:icon_bigg
It always feels awesome before the boom :D
I had a sim sit, lost the wastgate line, whole car pitched sidways, slammed into boost cut but I was on 93 with a good tune so it only leaned out to 12.2:1 even with the spike. That was an interesting log to look over lol.
good luck with the rebuild hope you have at least learned something
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
unleaded: 85
mid: 87
premium: 91
that is likely due to your altitude.
motor requires less octane with lower air density.
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
IwantMKIII;1495070 said:
Now cheaping out on a decent boost controller...well, I guess now you know, stick with EBC's.
Having personally seen every time I drive just how much boost fluctuates with temperature change alone, i will NEVER run a manual controller...EVER.
EDIT: didn't see that 'jk'. Ill keep my comment in place for others though :)
My Dr. Jonez manual controller works just fine. I'm sure I'll upgrade to an EBC whenever I get the boost up past 12 though.
hottscennessey;1495360 said:
They work, but one treatment only raises the octane 1 point. Meaning 1/10th of an octane.
the nos shit says it adds up to 3 points with 1 bottle/16gal. i have a bottle just never used it.
