Turbofreak's 1992 Poopra (Update 3/16/08)
Sawbladz
1,727
Oshawa, ON, CA
TurboFreak;892955 said:
So someone school me about the afterfixingBHG process. Is it ok for it to blow white smoke out still? I'm guessing it will go away? (It still could be the car being not warmed up plus 20 degree weather but I'm just paranoid) Do I need to find a timing gun and do that jammy?
Only problems I have now are that the timing belt is a little loose causing it to come up and hit the timing cover when I give it some gas. Its not loose enough to skip any teeth though.
And my idle is at 1500 rpms.
Thoughts on these problems?
I would be replacing the tensioner for sure. Also, did you smell the exhaust? I'd bet it's just condensation and you are driving yourself crazy.;)
MK3.0dudeman
brian L.
Mar 12, 2007
1,628
North Jersey
TurboFreak;892936 said:
Wrong. There is no way in heck the head will go on with those studs installed...haha. I snapped that pic before i took them all back out. haha.
GOD DAMNIT I got schoold owell at least I know now so I don't look like a dumb ass one day trying to do that.It looked like it would fit and plus on all the hondas i use to do they just slide one.
I would say it's a few things the fact that you had a bhg and the motors cleaning itself out,and the fact that it's hella cold.
heres what you should do let the car run outside for about 30 minutes and than bring it in the shop shut the door(but leave it open a bit) and let it run for about 2 minutes.see what happends than
TurboFreak
NOBAMA
Jan 22, 2006
1,374
East Coast
K so I worked on it today.
Coolant leak fixed? Check.
Vacuum lines all routed correctly? Check.
Another coolant leak found? Check.
Car stills idles funny cause of hopefully timing? Check.
ilikebigbutts
workin' my dream
Jun 10, 2007
347
Pittsburgh
hey man just wanted to say that the white 92 package looks SICK.i dont blaming you for selling teh 88 haha
also very nice job fixing the bhg have you driven it yet?
TurboFreak
NOBAMA
Jan 22, 2006
1,374
East Coast
Ahhhh it drives and it drives well! I drove it around for like 30-45 min. today and no overheating, no smoking, no weird noises, no leaks, no oil pressure issue, no idle issue, and everything works....Wooot! Ahhh I'm soo excited. I can't believe I pulled this off!
TurboFreak
NOBAMA
Jan 22, 2006
1,374
East Coast
hottscennessey;895190 said:
Congrats bro, now enjoy it :)
Exactly. It getting H&R coils(found out it has KYB struts on it) and some 25mm wheel spacers and thats it. Maybe some small stuff other than those things but that's pretty much it.
MK3.0dudeman
brian L.
Mar 12, 2007
1,628
North Jersey
good job man.I'm happy for you and you have a bad ass car this time.please post pics up a.s.a.p. of the spacers when there in.Also were are you getting them and how much do they run for?
TurboFreak
NOBAMA
Jan 22, 2006
1,374
East Coast
They are Eibach spacers and they are about....free. Look up Project Kic spacers. They're a good brand about $200 or a little more for all four. You're gonna want 5x114.3 and for normal people a 10mm(wheel will now be +28) spacer would look pretty good. The ones I got are +25mm (brings the wheel out to +13 offset) which is pretty aggressive and will definitely need to roll the fenders and maybe a slight pull.
PS: Your gonna wanna search for bolt-on spacers. None of that slip-on stuff.
MK3.0dudeman
brian L.
Mar 12, 2007
1,628
North Jersey
I see.I might do this.I'm guessing your keeping the stock white wheels.I have the same wheels just not in white and I do think they sit to far back in the wheel well
p.s. is that you welding your diff?
