Tuning the MAFT - Grimm
rakkasan
Currahee!!
Fort Campbell, KY
Strange, but I'll take it. :D
Question: When doing a light pull from 30-45mph, I'm getting 2.5v, which is good, but when I cruise at let's say 35mph, it goes up to 3.75v (or even 5.0v briefly). Is that normal? :confused:
dbsupra90
toonar
indiucky
oh you had the aux wire hooked up? if you had this enabled it will add or subtract that amount from the whole fuel trim. cool thing about it is you can use it to set up a secondary map when enabled. such as set 1 fuel trim for street driving and pump gas then enable for high boost and race gas. problem is you have to remember to change it back and forth. you could use a boost switch to auto enable aux mode at a certain boost level, but thats adding complication and something else to go wrong haha.
either way, glad you got it sorted. if you did have #4 on dont forget what you were tweaking was the wot map. you might want to go back and turn it on, 0 everything back out and reset again just to be sure.
good luck!
dave
rakkasan
Currahee!!
Fort Campbell, KY
good luck!
dave
Thanks for all the help, same to Grim & Cnewingham. Funny thing is, it's only temporary. I'll end up with a SAFC in the near future. If you think I have questions now..... :biglaugh:
C
cnewingham
Guest
I am also using an SAFC with my MAFT. you can only get the fine tuning by adding an safc. The maft is a rough tuning device and it shows from my dyno tuning sessions but it is an awesome upgrade to have. When youu get the SAFC put in and tuned you will be very happy.
malloynx
NC
yes. on my wideband i'll see 18:1 on the deccel. it's completly normal
B
bbaacchhyy
Guest
Been watching this thread guys, and am glad it is sorted and have learnt heaps from it.
Quick question though, how much benefit over the MAFT will the SAFC give ? Just better/finer mixture control or what ?
Cheers
Michael B
B
bbaacchhyy
Guest
Orion ZyGarian said:
Just more places to specifically tune your fuel ratio
If that is all, why bother with the extra expense and mucking around ?
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Tuning is a remarkable thing - it can make or break your car. Being able to tune to a more precise level is a very good thing, especially when you are aiming for higher than stock horsepower numbers.
dbsupra90
toonar
indiucky
i didnt care so much about the tuning aspect of it, but it is a benefit. big reasons for me were getting rid of the afm for more flow, cleaner design and bigger filter. also, i can blow off my ic piping or not even have them connected and drive my car just fine. a few others, can run shorter isc line (one less thing over the motor), "supposedly" quicker spool and hp, and finally no open vent bov stall.
mind you sev of the benefits above are from running blow thru only. otherwise its not much more than a fancy adjustable lex afm (which in its own right is nice if you have stock afm and no afc).
i think we need to compile some maft experiences, tuning and setup notes again. most of the good info was lost from the hack.
dave
rakkasan
Currahee!!
Fort Campbell, KY
dave
I think that's a great idea. IMO, it should be segmented by application. Draw thru vs. Blow thru, standard setting vs SAFC settings, ect.
C
cnewingham
Guest
I'll be running blow through with no SAFC
invest in the safc especially when setiing it up in blow thru. In draw through the maft is more of a plug and play item with minimal adjustments needed but in blow thru it is a different ball game.
Orion ZyGarian
Jeff Lange wannabe
Apr 2, 2005
1,490
Sarasota, FLorida
www.suprastore.com
I'm not made of money
The MAF-T is a cheap way to manage A/F, and I'm saving up for it, meaning I dont have much money to use for stuff! I just dont think it'd be worth it...I'd already have one way of managing fuel and as long as it doesnt spike lean or rich I think I'll be okay for now.
yannis-supras
Lag hater
Jun 13, 2005
331
Athens, Greece
This is very valuable information indeed, thanks a lot guys. I'm seriously considering going the maft way instead of a lex afm. My main concern is fuel cut. I was thinking of a standalone so as to be able to tune/set the fuel cut by will, not eliminate it. That would take a lot of money saving that I may do with out for the 500rwhp goal that I've set . The maft alternative is obviously a far better alternative moneywise just for that.
I've read that Grim manages to tune out fuel cut but could anyone clarify on this matter? Can fuel cut be set at will with the maft (and maybe SAFC if necessary) and if not when does it start to be a limitation power or boost wise?
