Rob (92NSX) and I just dyno'd at a dyno day today and guess what- we made the EXACT SAME POWER! All pulls were on a Dynojet RWD dyno.
Rob's mods are as follows -8an oil pick up hose, new oil pump shimmed 7mm, .040 over probes, eagle rods, balanced, HKS 1.2m MHG, BC 1mm over sized valves, BBC springs, BC 272 cams, Aeromotive A1000 AFPR, Lexus AFM, RX7 550's, P & P, Gates Racing T-belt, AEM cam gears, FFIM, fake SSQV bov, FMIC, K&N filter, 3" DP and test pipe, HKS super turbo exh., profec A EBC, BOSS Sr. - P-trim 61mm, GTS housing triple ceramic ball bearing - polished turbo, thermostatic - full flow - remote oiling system Stock clutch and PP.
15lbs of boost gave him 417.41 HP and 382.81 TQ.
ALL ON THE OEM/***NONPIGGYBACKED ECU The only tuning device was fuel pressure.
My car, on the other hand...
Put down 417.41HP and 391.44 tq
Has a fully built 7M, with pretty much the same mods, but no cams, or headwork. Almost everything is the same otherwise. I have a long runner intake mani with the stock TB, AEM EMS, 2JZ-GE ignition system, sequential injection, 720 injectors, and a mk4 TT fuel pump.
Here;s the dyno charts: robs's runs, most at 15ish PSI
My dyno runs, most at 18ish PSI
I know the main difference was Rob's cams, but DAMN! I wanted to at least do 450 vs the dyno dynamics I tuned on...
